Variational Tetrahedral Meshing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2005
Pierre Alliez
Mariette Yvinec
Mathieu Desbrun
In this paper, a novel Delaunay-based variational approach to isotropic tetrahedral meshing is presented. To achieve both robustness and efficiency, we minimize a simple mesh-dependent energy through global updates of both vertex positions \italic{and} connectivity. As this energy is known to be the ${\cal L}^1$ distance between an isotropic quadratic function and its linear interpolation on the mesh, our minimization procedure generates well-shaped tetrahedra. Mesh design is controlled through a gradation smoothness parameter and selection of the desired number of vertices. We provide the foundations of our approach by explaining both the underlying variational principle and its geometric interpretation. We demonstrate the quality of the resulting meshes through a series of examples.
tetmeshing.pdf (13.14 Mo) Télécharger le fichier
inria-00226418 , version 1 (30-01-2008)
Pierre Alliez, David Cohen-Steiner, Mariette Yvinec, Mathieu Desbrun. Variational Tetrahedral Meshing. ACM Transactions on Graphics, 2005, ⟨10.1145/1186822.1073238⟩. ⟨inria-00226418⟩
530 Consultations
521 Téléchargements
