A. , N. And-bern, and M. , Surface Reconstruction by Voronoi Filtering, Proc. of 14 th Symp. on Computational Geometry (SCG'98), pp.39-48, 1998.
A. , N. Choi, S. Dey, T. And-leekhau, and N. , A Simple Algorithm for Homeomorphic Surface Reconstruction, Proceedings of the Symposium on Computational geometry, pp.213-222
B. , J. And-oudot, and S. , Provably Good Sampling and Meshing of Surfaces, Graphical Models (special issue on Solid Modeling, 2005.
B. , H. George, P. Hecht, F. Laug, P. And-saltel et al., Delaunay mesh generation governed by metric specifications, Part Algorithms. Finite Elements in Analysis and Design, vol.1, issue.25, pp.61-83, 1997.
B. , H. George, P. And-mohammadi, and B. , Delaunay mesh generation governed by metric specifications. Part 2 : Application examples, Finite Elements in Analysis and Design, vol.25, pp.85-109, 1997.
C. , L. And-xu, and J. , Optimal Delaunay triangulations, Journal of Computational Mathematics, vol.22, issue.2, pp.299-308, 2004.
C. , S. W. And-dey, and T. K. , Quality meshing with weighted Delaunay refinement, Proc. 13 th ACM-SIAM Sympos. Discrete Algorithms, pp.137-146, 2002.
C. , S. And-poon, and S. , Graded conforming Delaunay tetrahedralization with bounded radius-edge ratio, Proc, of the 14 th ACM-SIAM Symposium on Discrete algorithms (SODA), pp.295-304, 2003.
C. , S. Dey, T. K. Edelsbrunner, H. Facello, M. A. And-teng et al., Sliver Exudation, Proc. 15th ACM Symp, pp.1-13, 1999.
C. , S. Dey, T. K. Ramos, E. And-ray, and T. , Quality Meshing for Polyhedra with Small Angles, Proc. of ACM Symp. on Comp. Geom, pp.290-299, 2004.
C. , D. De-verdiere, E. C. And-yvinec, and M. , Conforming Delaunay triangulations in 3D, Proc. of Symp. on Comp. Geom, pp.237-246, 2002.
URL : https://hal.archives-ouvertes.fr/inria-00072243
C. , B. Dorsey, J. And-mcmillan, and L. , Simplification and Improvement of Tetrahedral Models for Simulation, Proceedings of the 2004 Eurographics/ACM SIGGRAPH Symposium on Geometry Processing, pp.95-104, 2004.
D. , Q. And-wang, and D. , Tetrahedral mesh generation and optimization based on centroidal Voronoi tessellations, International Journal on Numerical Methods in Engineering, vol.56, issue.9, pp.1355-1373, 2003.
D. , Q. Gunzburger, M. And-ju, and L. , Constrained Centroidal Voronoi Tessellations for Surfaces, SIAM J. Sci. Comput, vol.24, issue.5, pp.1488-1506, 2003.
F. , A. Giezeman, G. Kettner, L. Schirra, S. And-sch¨onherrsch¨-sch¨onherr et al., On the Design of CGAL, a Computational Geometry Algorithms Library, Softw. ? Pract. Exp, vol.30, issue.11, pp.1167-1202, 2000.
F. , L. And-ollivier-gooch, and C. , A comparison of Tetrahedral Mesh Improvement Techniques, Proc. of 6th Int. Meshing Roundtable, 1996.
F. , J. L. And-george, and P. L. , Mesh Generation: Applications to Finite Elements, 2000.
H. , D. P. And-saff, and E. B. , Discretizing Manifolds via Minimum Energy Points, Notices of the AMS, vol.51, issue.10, pp.1186-1194, 2004.
K. , P. And-ortiz, and M. , Variational Delaunay Approach to the Generation of Finite Element Meshes, Int. J. for Num. Meth. in Eng, vol.50, issue.7, pp.1681-1700, 2001.
L. , X. And-teng, and S. , Generate Sliver Free Three Dimensional Mesh, Proc. 12 th ACM-SIAM Sympos. Discrete Algorithms, 2001.
L. , X. Teng, S. And-ungor, and A. , Biting: Advancing Front Meets Sphere Packing, Int. J. on Num. Methods in Eng, vol.49, issue.1, pp.61-81, 2000.
M. , S. And-vavasis, and S. , Quality Mesh Generation in Higher Dimensions, SIAM J. Sci. Comput, vol.29, pp.1334-1370, 2000.
M. , N. Bridson, R. Teran, J. And-fedkiw, and R. , A Crystalline, Red Green Strategy for Meshing Highly Deformable Objects with Tetrahedra, Proceedings of the 12th International Meshing Roundtable, pp.103-114, 2003.
Q. , W. R. Shimada, K. , A. Owen, and S. J. , 3D Discrete Skeleton Generation by Wave Propagation on PR-Octree for Finite Element Mesh Sizing, 2004.
S. , V. Alliez, P. And-gotsman, and C. , Isotropic Remeshing of Surfaces: a Local Parameterization Approach, Proc. of 12 th Int. Meshing Roundtable, 2003.
URL : https://hal.archives-ouvertes.fr/inria-00071612
T. , S. Wong, C. W. And-lee, and D. T. , Unstructured Mesh Generation: Theory, Practice, and Perspectives, International Journal Computational Geometry and Applications, vol.10, pp.3-227, 2000.
W. , J. Schaefer, S. Hirani, A. And-desbrun, and M. , Barycentric Coordinates for Convex Sets, 2004.
