Constructing elliptic curves with a known number of points over a prime field, High Primes and Misdemeanours: Lectures in Honour of the 60th Birthday of H C Williams, pp.1-17, 2004. ,
DOI : 10.1090/fic/041/01
Elliptic curves and primality proving, Mathematics of Computation, vol.61, issue.203, pp.29-68, 1993. ,
DOI : 10.1090/S0025-5718-1993-1199989-X
URL : https://hal.archives-ouvertes.fr/inria-00075302
A $p$-adic algorithm to compute the Hilbert class polynomial, Mathematics of Computation, vol.77, issue.264, 2007. ,
DOI : 10.1090/S0025-5718-08-02091-7
Supersingular elliptic curves and maximal quaternionic orders, Math. Institut G-A-Univ. Göttingen, pp.53-60, 2004. ,
A course in computational algebraic number theory. GTM 138, 1996. ,
Handbook of Elliptic and Hyperelliptic Curve Cryptography. Discrete mathematics and its applications, 2006. ,
Action of Modular Correspondences around CM Points, LNCS, vol.2369, pp.234-243, 2002. ,
DOI : 10.1007/3-540-45455-1_19
Die Typen der Multiplikatorenringe elliptischer Funktionenk??rper, Abhandlungen aus dem Mathematischen Seminar der Universit??t Hamburg, vol.14, issue.1, pp.197-272, 1941. ,
DOI : 10.1007/BF02940746
The complexity of class polynomial computation via floating point approximations . HAL-INRIA 1040 and ArXiv cs, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00001040
Constructing elliptic curves over finite fields using double eta-quotients, Journal de Th??orie des Nombres de Bordeaux, vol.16, issue.3, pp.555-568, 2004. ,
DOI : 10.5802/jtnb.460
URL : http://archive.numdam.org/article/JTNB_2004__16_3_555_0.pdf
Isogeny Volcanoes and the SEA Algorithm, ANTS-V, pp.276-291, 2002. ,
DOI : 10.1007/3-540-45455-1_23
Effective versions of the Chebotarev density theorem, Algebraic Number Fields (L-functions and Galois properties), pp.409-464, 1977. ,
Elliptic Functions. GTM 112, 1987. ,
), Proceedings of the London Mathematical Society, vol.2, issue.1, pp.358-372, 1928. ,
DOI : 10.1112/plms/s2-27.1.358
Weber's class invariants revisited, Journal de Th??orie des Nombres de Bordeaux, vol.14, issue.1, pp.325-343, 2002. ,
DOI : 10.5802/jtnb.361
The exponents of the groups of points on the reductions of an elliptic curve, Arithmetic Algebraic Geometry, pp.325-335, 1991. ,
DOI : 10.1007/978-1-4612-0457-2_15
Counting points on elliptic curves over finite fields, Journal de Th??orie des Nombres de Bordeaux, vol.7, issue.1, pp.219-254, 1995. ,
DOI : 10.5802/jtnb.142
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.56.4044
Einige Bemerkungen zu der vorstehenden Arbeit des Herrn G. Pólya: ¨ Uber die Verteilung der quadratischen Reste und Nichtreste, Nachr. Kön. Ges. Wiss. Göttingen, Math.-Phys. Kl, pp.30-36, 1918. ,
Hilbert's 12th problem, complex multiplication and Shimura reciprocity, Class field theory?its centenary and prospect, pp.161-176, 2001. ,
Modern Computer Algebra, 1999. ,
DOI : 10.1017/CBO9781139856065
Abelian varieties over finite fields, Annales scientifiques de l'??cole normale sup??rieure, vol.2, issue.4, pp.521-560, 1969. ,
DOI : 10.24033/asens.1183
