Reports
Stabilization of explicit coupling in fluid-structure interaction involving fluid incompressibility
Erik Burman 1 Miguel Angel Fernández 2
2 REO - Numerical simulation of biological flows
LJLL - Laboratoire Jacques-Louis Lions, Inria Paris-Rocquencourt, UPMC - Université Pierre et Marie Curie - Paris 6
Abstract : In this work we propose a stabilized explicit coupling scheme for fluid-structure interaction problems involving a viscous incompressible fluid. The coupled discrete formulation is based on Nitsche's method with a time penalty term giving L^2-control on the fluid force variations at the interface. The scheme is stable, in the energy norm, irrespectively of the fluid-structure density ratio. Numerical experiments, in two and three dimensions, show that optimal time accuracy can be obtained by performing a few defect-correction iterations
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00247409
Contributor : Miguel Angel Fernández Connect in order to contact the contributor
Submitted on : Thursday, February 7, 2008 - 9:56:02 PM
Last modification on : Tuesday, January 11, 2022 - 11:16:21 AM
Long-term archiving on: : Thursday, September 27, 2012 - 5:52:10 PM
File
burman-fernandez-08.pdf
Identifiers
  • HAL Id : inria-00247409, version 1
Citation
Erik Burman, Miguel Angel Fernández. Stabilization of explicit coupling in fluid-structure interaction involving fluid incompressibility. [Research Report] 2008. ⟨inria-00247409v1⟩
Share
Metrics
Les métriques sont temporairement indisponibles
