New interface
Journal articles
Stabilization of explicit coupling in fluid-structure interaction involving fluid incompressibility
Erik Burman 1 Miguel Angel Fernández 2
2 REO - Numerical simulation of biological flows
LJLL - Laboratoire Jacques-Louis Lions, Inria Paris-Rocquencourt, UPMC - Université Pierre et Marie Curie - Paris 6
Abstract : In this work we propose a stabilized explicit coupling scheme for fluid-structure interaction problems involving a viscous incompressible fluid. The coupled discrete formulation is based on Nitsche's method with a time penalty term giving L^2-control on the fluid pressure variations at the interface. The scheme is stable, in the energy norm, irrespectively of the fluid-structure density ratio. Numerical experiments, in two and three dimensions, show that optimal time accuracy can be obtained by performing a few defect-correction iterations
Document type :
Journal articles
Complete list of metadata
Cited literature [42 references]  Display  Hide  Download
https://hal.inria.fr/inria-00247409
Contributor : Miguel Angel Fernández Connect in order to contact the contributor
Submitted on : Thursday, October 23, 2008 - 12:22:54 AM
Last modification on : Friday, January 21, 2022 - 3:21:50 AM
Long-term archiving on: : Saturday, November 26, 2016 - 2:23:55 AM
File
RR-6445.pdf
Identifiers
Citation
Erik Burman, Miguel Angel Fernández. Stabilization of explicit coupling in fluid-structure interaction involving fluid incompressibility. Computer Methods in Applied Mechanics and Engineering, 2009, 198 (5-8), pp.766-784. ⟨10.1016/j.cma.2008.10.012⟩. ⟨inria-00247409v4⟩
Share
Metrics
Record views
186
Files downloads
1139
