Fluid???structure partitioned procedures based on Robin transmission conditions, Journal of Computational Physics, vol.227, issue.14, pp.7027-7051, 2008. ,
DOI : 10.1016/j.jcp.2008.04.006
Finite element developments for general fluid flows with structural interactions, International Journal for Numerical Methods in Engineering, vol.60, issue.1, 2004. ,
DOI : 10.1002/nme.959
A finite element method for domain decomposition with non-matching grids, ESAIM: Mathematical Modelling and Numerical Analysis, vol.37, issue.2, pp.209-225, 2003. ,
DOI : 10.1051/m2an:2003023
URL : https://hal.archives-ouvertes.fr/inria-00073065
Stabilized explicit coupling for fluidstructure interaction using Nitsche's method, C. R. Math. Acad. Sci. Paris, issue.8, pp.345467-472, 2007. ,
A unified stabilized method for Stokes??? and Darcy's equations, Journal of Computational and Applied Mathematics, vol.198, issue.1, pp.35-51, 2007. ,
DOI : 10.1016/j.cam.2005.11.022
A Domain Decomposition Method Based on Weighted Interior Penalties for Advection???Diffusion???Reaction Problems, SIAM Journal on Numerical Analysis, vol.44, issue.4, pp.1612-1638, 2006. ,
DOI : 10.1137/050634736
Added-mass effect in the design of partitioned algorithms for fluid???structure problems, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.42-44, pp.42-444506, 2005. ,
DOI : 10.1016/j.cma.2004.12.005
URL : https://hal.archives-ouvertes.fr/inria-00071499
Fluidstructure algorithms based on Steklov-Poincaré operators, Comput. Methods Appl. Mech. Engrg, vol.195, pp.41-435797, 2006. ,
Acceleration of a fixed point algorithm for fluid-structure interaction using transpiration conditions, ESAIM: Mathematical Modelling and Numerical Analysis, vol.37, issue.4, pp.601-616, 2003. ,
DOI : 10.1051/m2an:2003050
URL : https://hal.archives-ouvertes.fr/hal-00705114
An arbitrary lagrangian-eulerian finite element method for transient dynamic fluid-structure interactions, Computer Methods in Applied Mechanics and Engineering, vol.33, issue.1-3 ,
DOI : 10.1016/0045-7825(82)90128-1
Provably second-order timeaccurate loosely-coupled solution algorithms for transient nonlinear aeroelasticity, Comput. Methods Appl. Mech. Engrg, vol.195, pp.17-181973, 2006. ,
A projection semi-implicit scheme for the coupling of an elastic structure with an incompressible fluid, International Journal for Numerical Methods in Engineering, vol.9, issue.4, pp.794-821, 2007. ,
DOI : 10.1002/nme.1792
An exact Block???Newton algorithm for solving fluid???structure interaction problems, Comptes Rendus Mathematique, vol.336, issue.8, pp.336681-686, 2003. ,
DOI : 10.1016/S1631-073X(03)00151-1
A Newton method using exact jacobians for solving fluid???structure coupling, Computers & Structures, vol.83, issue.2-3, pp.127-142, 2005. ,
DOI : 10.1016/j.compstruc.2004.04.021
On the coupling of 3D and 1D Navier???Stokes equations for flow problems in compliant vessels, Computer Methods in Applied Mechanics and Engineering, vol.191, issue.6-7, pp.6-7561, 2001. ,
DOI : 10.1016/S0045-7825(01)00302-4
URL : https://hal.archives-ouvertes.fr/inria-00072794
Artificial added mass instabilities in sequential staggered coupling of nonlinear structures and incompressible viscous flows, Computer Methods in Applied Mechanics and Engineering, vol.196, issue.7, pp.1278-1293, 2007. ,
DOI : 10.1016/j.cma.2006.09.002
A Quasi-Newton Algorithm Based on a Reduced Model for Fluid-Structure Interaction Problems in Blood Flows, ESAIM: Mathematical Modelling and Numerical Analysis, vol.37, issue.4, pp.631-648, 2003. ,
DOI : 10.1051/m2an:2003049
URL : https://hal.archives-ouvertes.fr/inria-00071895
Nitsche's method for interface problems in computa-tional mechanics, GAMM-Mitteilungen, vol.15, issue.2, pp.183-206, 2005. ,
DOI : 10.1002/gamm.201490018
Nitsche's method for coupling non-matching meshes in fluid-structure vibration problems, Computational Mechanics, vol.32, issue.1-2, pp.134-139, 2003. ,
DOI : 10.1007/s00466-003-0467-7
Nitsche's method combined with space???time finite elements for ALE fluid???structure interaction problems, Computer Methods in Applied Mechanics and Engineering, vol.193, issue.39-41, pp.4195-4206, 2004. ,
DOI : 10.1016/j.cma.2003.09.029
FreeFem++ v. 2.11. User's Manual ,
Optimization of fluid-structure interaction scheme for arterial flow simulations, 2nd International Symposium on Modelling of Physiological Flows ? MPF 2005, 2005. ,
A defect-correction method for the incompressible Navier???Stokes equations, Applied Mathematics and Computation, vol.129, issue.1, pp.1-19, 2002. ,
DOI : 10.1016/S0096-3003(01)00026-1
Fluid structure interaction with large structural displacements, Comput. Meth. Appl. Mech. Engrg, vol.190, pp.3039-3067, 2001. ,
Partitioned analysis schemes for the transient interaction of incompressible flows and nonlinear flexible structures ,
Partitioned analysis approach for the transient, coupled response of viscous fluids and flexible structures, Proceedings of the European Conference on Computational Mechanics. ECCM'99, 1999. ,
Accelerated iterative substructuring schemes for instationary fluid-structure interaction, Computational Fluid and Solid Mechanics, pp.1325-1328, 2001. ,
DOI : 10.1016/B978-008043944-0/50907-0
Fluid-Structure Interaction: Applied Numerical Methods, 1995. ,
??ber ein Variationsprinzip zur L??sung von Dirichlet-Problemen bei Verwendung von Teilr??umen, die keinen Randbedingungen unterworfen sind, Abhandlungen aus dem Mathematischen Seminar der Universit??t Hamburg, vol.12, issue.1, pp.9-15, 1971. ,
DOI : 10.1007/BF02995904
Numerical approximation of fluid-structure interaction problems with application to haemodynamics, 2001. ,
Stabilization of staggered solution procedures for fluid-structure interaction analysis, Computational Methods for Fluid-Structure Interaction Problems, pp.95-124, 1977. ,
Simulation numérique de phénomènes d'interaction fluidestructure, Ecole Nationale des Ponts et Chaussées, 1995. ,
Explicit/implicit fluid/structure staggered procedures with a structural predictor and fluid subcycling for 2D inviscid aeroelastic simulations, International Journal for Numerical Methods in Fluids, vol.134, issue.10, pp.251207-1226, 1997. ,
DOI : 10.1002/(SICI)1097-0363(19971130)25:10<1207::AID-FLD616>3.0.CO;2-R
URL : https://hal.archives-ouvertes.fr/hal-00607776
A SEMI-IMPLICIT APPROACH FOR FLUID-STRUCTURE INTERACTION BASED ON AN ALGEBRAIC FRACTIONAL STEP METHOD, Mathematical Models and Methods in Applied Sciences, vol.17, issue.06, pp.957-983, 2007. ,
DOI : 10.1142/S0218202507002170
Fluid-structure interaction boundary conditions by artificial compressibility, ECCOMAS Computational Fluid Dynamics Conference, 2001. ,
Coupling of a Navier-Stokes solver and an elastic boundary solver for unsteady problems, Computational Fluid Dynamics '98: Proceeding of the Fourth European Computational fluid Dynamics Conference, pp.1040-1045, 1998. ,
The defect correction principle and discretization methods, Numerische Mathematik, vol.11, issue.4, pp.425-443, 1978. ,
DOI : 10.1007/BF01432879
Finite Element Methods for Fluid Dynamics with Moving Boundaries and Interfaces, Arch. Comput. Methods Engrg, vol.8, pp.83-130, 2001. ,
DOI : 10.1002/0470091355.ecm069
Galerkin finite element methods for parabolic problems, of Springer Series in Computational Mathematics, 2006. ,
DOI : 10.1007/978-3-662-03359-3
Computer Simulation of Intraventricular Flow and Pressure Gradients During Diastole, Journal of Biomechanical Engineering, vol.122, issue.6, pp.667-674, 2000. ,
DOI : 10.1115/1.1318941
Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès-Nancy Cedex (France) Unité de recherche INRIA Rennes : IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Rhône-Alpes : 655, avenue de l'Europe -38334 Montbonnot Saint-Ismier (France) Unité de recherche, 2004. ,
BP 105 -78153 Le Chesnay Cedex (France) http://www.inria.fr ISSN, pp.249-6399 ,
