Estimation of Roughness Profile in Trapezoidal Open Channels, Journal of Hydraulic Engineering, vol.125, issue.3, pp.309-312, 1999. ,
DOI : 10.1061/(ASCE)0733-9429(1999)125:3(309)
Data assimilation (4D-VAR) to forecast flood in shallow-waters with sediment erosion, Journal of Hydrology, vol.300, issue.1-4, pp.1-4, 2005. ,
DOI : 10.1016/j.jhydrol.2004.06.009
Assimilation of Lagrangian data into a numerical model, Dynamics of Atmospheres and Oceans, vol.13, issue.3-4, pp.335-348, 1989. ,
DOI : 10.1016/0377-0265(89)90045-6
Variational assimilation of meteorological observations with the direct and adjoint shallow-water equations, Tellus A, vol.42, issue.5, pp.531-549, 1990. ,
DOI : 10.1034/j.1600-0870.1990.t01-4-00004.x
River gauging using PIV techniques: a proof of concept experiment on the Iowa River, Journal of Hydrology, vol.277, issue.3-4, pp.182-194, 2003. ,
DOI : 10.1016/S0022-1694(03)00081-7
Identification of Manning???s Roughness Coefficients in Shallow Water Flows, Journal of Hydraulic Engineering, vol.130, issue.6, pp.501-510, 2004. ,
DOI : 10.1061/(ASCE)0733-9429(2004)130:6(501)
Some numerical experiments with variable-storage quasi-Newton algorithms, Mathematical Programming, vol.11, issue.2, pp.407-435, 1989. ,
DOI : 10.1007/BF01589113
Evaluating Derivatives: Principles and Techniques of Algorithmic Differentiation, Frontiers in Appl. Math. SIAM, vol.19, 2000. ,
DOI : 10.1137/1.9780898717761
Data assimilation in river flow modelling In: 4 th DHI software conference, Scanticon Conference Center, pp.6-8, 2001. ,
Tapenade 2.1 user's guide, 2004. ,
Dassflow : a direct and adjoint model for 2d shallow water flows, Research Report RR? INRIA, vol.5756, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00070264
Continuous data assimilation of drifting buoy trajectory into an equatorial Pacific Ocean model, Journal of Marine Systems, vol.6, issue.1-2, pp.159-178, 1995. ,
DOI : 10.1016/0924-7963(94)00022-4
Identification Problem of Open-Channel Friction Parameters, Journal of Hydraulic Engineering, vol.123, issue.12, pp.1078-1088, 1997. ,
DOI : 10.1061/(ASCE)0733-9429(1997)123:12(1078)
A Method for Assimilation of Lagrangian Data, Monthly Weather Review, vol.131, issue.10, pp.2247-2260, 2003. ,
DOI : 10.1175/1520-0493(2003)131<2247:AMFAOL>2.0.CO;2
Variational algorithms for analysis and assimilation of meteorological observations: theoretical aspects, Tellus A, vol.109, issue.2, pp.97-110, 1986. ,
DOI : 10.1111/j.1600-0870.1986.tb00459.x
Balancing Source Terms and Flux Gradients in High-Resolution Godunov Methods: The Quasi-Steady Wave-Propagation Algorithm, Journal of Computational Physics, vol.146, issue.1, pp.346-365, 1998. ,
DOI : 10.1006/jcph.1998.6058
Optimal control of systems governed by partial differential equations, 1971. ,
DOI : 10.1007/978-3-642-65024-6
Data assimilation in a flood modelling system using the Ensemble Kalman filter, 2006. ,
Assimilation de données pour les modèles d'hydraulique fluviale Estimation de paramètres, analyse de sensibilité et décomposition de domaine, p.LMC?IMAG, 2003. ,
Validation and Extension of Image Velocimetry Capabilities for Flow Diagnostics in Hydraulic Modeling, Journal of Hydraulic Engineering, vol.130, issue.3, pp.175-185, 2004. ,
DOI : 10.1061/(ASCE)0733-9429(2004)130:3(175)
Variational assimilation of Lagrangian data in oceanography, Inverse Problems, vol.22, issue.1, pp.245-263, 2006. ,
DOI : 10.1088/0266-5611/22/1/014
URL : https://hal.archives-ouvertes.fr/inria-00173069
Data assimilation applied to hydraulic parameter identification hydrology: science and practice for the 21st century, pp.354-361, 2004. ,
A Method for Assimilating Lagrangian Data into a Shallow-Water-Equation Ocean Model, Monthly Weather Review, vol.134, issue.4, pp.1081-1101, 2006. ,
DOI : 10.1175/MWR3104.1
Variational Assimilation of Meteorological Observations With the Adjoint Vorticity Equation. I: Theory, Quarterly Journal of the Royal Meteorological Society, vol.8, issue.10, pp.1311-1328, 1987. ,
DOI : 10.1002/qj.49711347812
Shock-capturing methods for free-surface shallow flows, J. Wiley and Sons, 2001. ,
Assimilation de données variationnelle pour les probì emes de transport des sédiments enrivì ere, p.LMC?IMAG, 1999. ,
