Experimental evidence of nonlocal hydrodynamic influence on the dynamic contact angle, Physics of Fluids, vol.11, issue.8, 1995. ,
DOI : 10.1063/1.870063
The dynamics of the spreading of liquids on a solid surface. Part 1. Viscous flow, Journal of Fluid Mechanics, vol.81, issue.-1, pp.169-194, 1986. ,
DOI : 10.1021/ie50320a024
On the motion of a fluid-fluid interface along a solid surface, Journal of Fluid Mechanics, vol.14, issue.01, pp.1-71, 1974. ,
DOI : 10.1016/0021-9797(71)90280-3
Wettings: statics and dynamics, Rev. Mod. Phys, vol.57, issue.3 3, 1985. ,
Elliptic Partial Differential Equations of Second Order Hocking, A moving fluid interface. Part II. The removal of the force singularity by a slip flow, J. Fluid, vol.5, 1977. ,
The moving contact line problem on a smooth solid surface, Int. J. Multiphase Flow, vol.7, issue.4, pp.589-610, 1993. ,
