Finite Eilenberg Machines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Benoit Razet
  • Fonction : Auteur
  • PersonId : 833443
Eilenberg machines define a general computational model. They are well suited to the simulation of problems specified using finite state formalisms such as formal languages and automata theory. This paper introduces a subclass of them called finite Eilenberg machines. We give a formal description of complete and efficient algorithms which permit the simulation of such machines. We show that our finiteness restriction ensures a correct behavior of the simulation. Interpretations of this restriction are studied for the particular cases of non-deterministic automata (NFA) and rational transducers, leading to applications to computational linguistics. The given implementation provides a generic simulation procedure for any problem encoded as a composition of finite Eilenberg machines.
fem.pdf (224.07 Ko) Télécharger le fichier
inria-00257354 , version 1 (25-02-2008)
inria-00257354 , version 2 (03-04-2008)
inria-00257354 , version 3 (04-04-2008)
  • HAL Id : inria-00257354 , version 2
Benoit Razet. Finite Eilenberg Machines. [Research Report] 2008. ⟨inria-00257354v2⟩
Collections
INRIA-RRRT
67 Consultations
169 Téléchargements
