New interface
Reports (Research report)
mQMA multi-constrained QoS Multicast Aggregation
Abstract : Traditional IP Multicast has been proposed in order to manage group communications over the Internet in a bandwidth efficient manner. Although this proposition has been well studied during the last decade there are still some problems for its deployment. In this paper, we propose a new algorithm mQMA that deals with two important problems of traditional IP multicast, i.e., multicast forwarding state scalability and Quality of Service routing. The algorithm mQMA deals with these two main problems while utilizing the technique of multicast aggregation in case of multi-constrained QoS. With this technique of aggregation several groups can share the same tree respecting the same QoS requirements. The algorithm mQMA builds trees satisfying multiple QoS constraints. We show, during the simulations, that mQMA reaches the same QoS performances as Mamcra which is the main multi-constrained multicast routing algorithm. Moreover, mQMA reduces dramatically the number of trees to be maintained and the number of multicast forwarding states.
Document type :
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/inria-00258515
Contributor : Ist Rennes Connect in order to contact the contributor
Submitted on : Thursday, March 6, 2008 - 4:55:08 PM
Last modification on : Wednesday, October 26, 2022 - 8:16:21 AM
Long-term archiving on: : Tuesday, September 21, 2010 - 4:14:17 PM
PI-1881-v2.pdf
Identifiers
  • HAL Id : inria-00258515, version 2
Citation
Naouel Ben Ali, Joanna Moulierac, Abdelfattah Belghith, Miklos Molnar. mQMA multi-constrained QoS Multicast Aggregation. [Research Report] PI 1881, 2008. ⟨inria-00258515v2⟩
Share
Metrics
Record views
252
Files downloads
697
