Environment Learning for Indoor Mobile Robots, 2006. ,
Online visual motion estimation using FastSLAM with SIFT features, 2005 IEEE/RSJ International Conference on Intelligent Robots and Systems, 2005. ,
DOI : 10.1109/IROS.2005.1545444
Monte Carlo localization for mobile robots, Proceedings 1999 IEEE International Conference on Robotics and Automation (Cat. No.99CH36288C), 1998. ,
DOI : 10.1109/ROBOT.1999.772544
A solution to the simultaneous localization and map building (SLAM) problem, IEEE Transactions on Robotics and Automation, vol.17, issue.3, pp.229-241, 2001. ,
DOI : 10.1109/70.938381
Rao-Blackwellised particle filtering for dynamic Bayesian networks, p.0, 2000. ,
Improving grid-based SLAM with Rao- Blackwellized particle filters by adaptive proposals and selective resampling, IEEE International Conference on Robotics & Automation (ICRA), 2005. ,
Unscented filtering and non-linear estimation, Proceedings of the IEEE, pp.401-422, 2004. ,
The spherical simplex unscented transformation, Proceedings of the 2003 American Control Conference, 2003., 2003. ,
DOI : 10.1109/ACC.2003.1243439
Metropolized independent sampling with comparisons to rejection sampling and importance sampling, Statistics and Computing, vol.82, issue.2, pp.113-119, 1996. ,
DOI : 10.1007/BF00162521
Unscented SLAM for large-scale outdoor environments, 2005 IEEE/RSJ International Conference on Intelligent Robots and Systems, 2005. ,
DOI : 10.1109/IROS.2005.1545002
FastSLAM: A Factored Solution to the Simultaneous Localization and Mapping Problem, p.2, 2002. ,
FastSLAM 2.0: An improved particle filtering algorithm for simultaneous localization and mapping that provably converges, Proc. of Int. Conf. on Artificial Intelligence (IJCAI), 2003. ,
On the Structure and Solution of the Simultaneous Localisation and Map Building Problem, 2000. ,
Fast- SLAM: An efficient solution to the simultaneous localization and mapping problem with unknown data association, Journal of Machine Learning Research, 2004. ,
The Unscented Particle Filter, Advances in Neural Information Processing Systems (NIPS13). T.K. Leen, 2000. ,
