New interface
Conference papers
Unsupervised Detection of Artificial Objects in Outdoor Environments
Abstract : This paper presents a novel unsupervised sensor fusion method to detect artificial objects in outdoor environments. We define artificial objects present in outdoor environments using structure and appearance information: an artificial object is composed of several smooth surfaces with sufficiently extended area and distinctive colors with respect to the environment. Structure information is obtained extracting smooth linked surfaces from 3D range data. Appearance information is computed on image data through a color processing. The problem of fusing these two different kinds of information is addressed through the use of a Bayesian sensor fusion approach. A probability map is built and then clustered with a 2.5D unsupervised self organizing network. This method defines objects according to the distribution of the probability values in the fusion map. The resulting clusters are labeled with their mean probability value representing the confidence the detected regions have of being artificial objects. In order to show the validity of the proposed algorithm some experiments have been performed in real outdoor environments showing promising results.
Document type :
Conference papers
Complete list of metadata
Cited literature [6 references]  Display  Hide  Download
https://hal.inria.fr/inria-00258780
Contributor : Inria Rhône-Alpes Documentation Connect in order to contact the contributor
Submitted on : Monday, February 25, 2008 - 12:12:12 PM
Last modification on : Monday, February 25, 2008 - 7:05:48 PM
Long-term archiving on: : Friday, September 28, 2012 - 10:10:38 AM
File
fsr_77.pdf
Identifiers
  • HAL Id : inria-00258780, version 1
Collections
Citation
Luciano Spinello, Roland Siegwart. Unsupervised Detection of Artificial Objects in Outdoor Environments. 6th International Conference on Field and Service Robotics - FSR 2007, Jul 2007, Chamonix, France. ⟨inria-00258780⟩
Share
Metrics
Record views
39
Files downloads
107
