Conference papers
Reactive Trajectory Deformation to Navigate Dynamic Environments
Vivien Delsart 1 Thierry Fraichard 1, *
* Corresponding author
1 E-MOTION - Geometry and Probability for Motion and Action
Inria Grenoble - Rhône-Alpes, LIG - Laboratoire d'Informatique de Grenoble
Abstract : Path deformation is a technique that was introduced to generate robot motion wherein a path, that has been computed beforehand, is continuously deformed on-line in response to unforeseen obstacles. In an effort to improve path deformation, this paper presents a trajectory deformation scheme. The main idea is that by incorporating the time dimension and hence information on the obstacles future behaviour, quite a number of situations where path deformation would fail can be handled. The trajectory represented as a space-time curve is subject to deformation forces both external (to avoid collision with the obstacles) and internal (to maintain trajectory feasibility and connectivity). The trajectory deformation scheme has been tested successfully on a planar robot with double integrator dynamics moving in dynamic environments.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00258976
Contributor : Thierry Fraichard Connect in order to contact the contributor
Submitted on : Wednesday, August 6, 2008 - 3:26:29 PM
Last modification on : Thursday, October 21, 2021 - 3:52:59 AM
Long-term archiving on: : Tuesday, September 21, 2010 - 5:28:27 PM
Identifiers
  • HAL Id : inria-00258976, version 2
Collections
Citation
Vivien Delsart, Thierry Fraichard. Reactive Trajectory Deformation to Navigate Dynamic Environments. European Robotics Symposium, Mar 2008, Prague, Czech Republic. ⟨inria-00258976v2⟩
Share
Metrics
Record views
309
Files downloads
683
