Integrated control of highway systems using flatness-based concept, Proc. SCS-IFAC, Int. Modeling Simulation Multiconf. -Int. Conf. Advances Vehicle Control and Safety, Buenos Aires, 2007. ,
Modélisation macroscopique du flux de trafic basé sur l'estimation paramétrique des modèles bond graphs, Actes 7 e Conf, 2008. ,
Model predictive control with repeated model fitting for ramp metering, Proceedings. The IEEE 5th International Conference on Intelligent Transportation Systems, 2002. ,
DOI : 10.1109/ITSC.2002.1041221
Analyse non standard du bruit, Comptes Rendus Mathematique, vol.342, issue.10, pp.797-802, 2006. ,
DOI : 10.1016/j.crma.2006.02.037
URL : https://hal.archives-ouvertes.fr/inria-00001134
An introduction to algebraic discretetime linear parametric identification with a concrete application, J. europ. syst. automat, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00188435
Robust residual generation for linear fault diagnosis: an algebraic setting with examples, International Journal of Control, vol.34, issue.14, pp.1223-1242, 2004. ,
DOI : 10.1080/002071704200024374
Non-linear estimation is easy, International Journal of Modelling, Identification and Control, vol.4, issue.1, 2008. ,
DOI : 10.1504/IJMIC.2008.020996
URL : https://hal.archives-ouvertes.fr/inria-00158855
Flatness and defect of non-linear systems: introductory theory and examples, International Journal of Control, vol.4, issue.6, pp.1327-1361, 1995. ,
DOI : 10.1109/9.73561
Continuous-time linear predictive control and flatness: A module-theoretic setting with examples, International Journal of Control, vol.73, issue.7, pp.606-623, 2000. ,
DOI : 10.1080/002071700219452
An algebraic framework for linear identification, ESAIM: Control, Optimisation and Calculus of Variations, vol.9, pp.151-168, 2003. ,
DOI : 10.1051/cocv:2003008
Closed-loop parametric identification for continuous-time linear systems via new algebraic techniques Continuous-Time Model Identification from Sampled Data, 2008. ,
A study of traffic capacity, Highway Research Board, vol.14, pp.448-477, 1935. ,
Two proposals to improve freeway traffic flow, California PATH Research Report, 1990. ,
On Kinematic Waves. II. A Theory of Traffic Flow on Long Crowded Roads, Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.229, issue.1178, pp.317-345, 1955. ,
DOI : 10.1098/rspa.1955.0089
Coordinated Ramp Metering Via Second Order Sliding Mode Control, 2006 IEEE Intelligent Transportation Systems Conference, pp.261-266, 2006. ,
DOI : 10.1109/ITSC.2006.1706752
Improved Online Estimation Methods for a Feedback-Based Freeway Ramp Metering Strategy, 2006 IEEE Intelligent Transportation Systems Conference, pp.412-417, 2006. ,
DOI : 10.1109/ITSC.2006.1706776
Alinea: A local feedback control law for on-ramp metering, Transportation Research Record, vol.1320, pp.58-64, 1991. ,
Operational calculus based on the two-sided Laplace integral, 1955. ,
Shock Waves on the Highway, Operations Research, vol.4, issue.1, pp.42-51, 1956. ,
DOI : 10.1287/opre.4.1.42
Commande des systèmes par platitude , Techniques de l'ingénieur, S7450, 2007. ,
Differentially Flat Systems, 2004. ,
Fliess and H. Mounier. Estimation of longitudinal and lateral vehicle velocities: An algebraic approach, Proc. Amer. Contr. Conf. ? ACC'08, 2008. ,
Real-time freeway traffic state estimation based on extended Kalman filter: a general approach, Transportation Research Part B: Methodological, vol.39, issue.2, pp.141-167, 2005. ,
DOI : 10.1016/j.trb.2004.03.003
A real-time freeway network traffic surveillance tool, IEEE Transactions on Control Systems Technology, vol.14, issue.1, pp.18-32, 2006. ,
DOI : 10.1109/TCST.2005.859636
Real-time parallel parameter estimators for a second-order macroscopic traffic flow model Proc. 9 th IEEE Intelligent Transportation Systems Conf, pp.1466-1470, 2006. ,
Design and evaluation of roadway controller for freeway traffic, Proc. 8 th IEEE Intelligent Transportation Systems Conf., Vienna, 2005. ,
