The generalized bas relief ambiguity, International Journal of Computer Vision, vol.35, issue.1, pp.33-44, 1999. ,
DOI : 10.1023/A:1008154927611
Level Set Segmentation With Multiple Regions, IEEE Transactions on Image Processing, vol.15, issue.10, 2006. ,
DOI : 10.1109/TIP.2006.877481
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.187.8458
Regularizing Flows for Constrained Matrix-Valued Images, Journal of Mathematical Imaging and Vision, vol.20, issue.1/2, pp.147-162, 2004. ,
DOI : 10.1023/B:JMIV.0000011324.14508.fb
In search of illumination invariants, Proceedings IEEE Conference on Computer Vision and Pattern Recognition. CVPR 2000 (Cat. No.PR00662) ,
DOI : 10.1109/CVPR.2000.855827
Robot vision, 1986. ,
Multi-view stereo reconstruction and scene flow estimation with a global image-based matching score. to appear in the international journal of computer vision, Intl. J. of Comp. Vis, 2006. ,
Variational Methods for Shape Reconstruction in Computer Vision, 2003. ,
Shedding light on stereoscopic segmentation, Proc. IEEE Conf. on Comp. Vision and Pattern Recogn, pp.36-42, 2004. ,
Multi-view stereo beyond lambert, Proc. IEEE Conf. on Comp. Vision and Pattern Recogn, pp.171-178, 2003. ,
Region-based segmentation on evolving surfaces with application to 3d shape and radiance estimation, Proc. of the Eur. Conf. on Comp. Vision, pp.114-125, 2004. ,
Mumford-Shah on the Move: Region-based Segmentation on Deforming Manifolds with Application to 3-D Reconstruction of Shape and Appearance from Video, 2006. ,
Estimation of 3D surface shape and smooth radiance from 2D images: A level set approach, Journal of Scientific Computing, vol.19, pp.1-3267, 2003. ,
Illuminant direction and shape of a bump, Journal of the Optical Society of America A, vol.15, issue.9, pp.2341-2350, 1998. ,
DOI : 10.1364/JOSAA.15.002341
Shape from shading and photometric stereo methods, 1998. ,
Photometric Invariants Related to Solid Shape, Optica Acta: International Journal of Optics, vol.50, issue.7, pp.981-996, 1980. ,
DOI : 10.1080/713820338
Robust Variational Segmentation of 3D Objects from Multiple Views, Pattern Recognition (Proc. DAGM), pp.688-697, 2006. ,
DOI : 10.1007/11861898_69
Nonlinear programming, Proceedings of the Second Berkeley Symposium on Mathematical Statistics and Probability, pp.481-492, 1951. ,
A theory of shape by space carving, Proceedings of the Seventh IEEE International Conference on Computer Vision, pp.199-218, 2000. ,
DOI : 10.1109/ICCV.1999.791235
Shape-from-shading on a cloudy day, Journal of the Optical Society of America A, vol.11, issue.2, pp.467-478, 1994. ,
DOI : 10.1364/JOSAA.11.000467
An invitation to 3D vision, from images to models, 2003. ,
Surface reflection: physical and geometrical perspectives, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.13, issue.7, pp.611-634, 1991. ,
DOI : 10.1109/34.85654
A global algorithm for shape from shading, 1993 (4th) International Conference on Computer Vision, pp.692-710, 1993. ,
DOI : 10.1109/ICCV.1993.378145
Fronts propagating with curvature-dependent speed: Algorithms based on Hamilton-Jacobi formulations, Journal of Computational Physics, vol.79, issue.1, pp.12-49, 1988. ,
DOI : 10.1016/0021-9991(88)90002-2
Application of the theory of the viscosity solutions to the Shape From Shading problem, 2004. ,
URL : https://hal.archives-ouvertes.fr/tel-00007916
Estimating the surface radiance function from single images, pp.494-501, 2004. ,
Surface radiance correction for shape-from-shading, Pattern Recognition, vol.38, issue.10, pp.1574-1595, 2005. ,
Illumination constraints in deformable models for shape and light direction estimation, IEEE Trans. Pattern Anal. Mach. Intell, pp.247-264, 2003. ,
Variable albedo surface reconstruction from stereo and shape from shading, Proceedings IEEE Conference on Computer Vision and Pattern Recognition. CVPR 2000 (Cat. No.PR00662), pp.480-487, 2000. ,
DOI : 10.1109/CVPR.2000.855858
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.120.4564
A Comparison and Evaluation of Multi-View Stereo Reconstruction Algorithms, 2006 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, Volume 1 (CVPR'06), pp.519-526, 2006. ,
DOI : 10.1109/CVPR.2006.19
Toward accurate recovery of shape from shading under diffuse lighting, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.19, issue.9, pp.1020-1025, 1997. ,
DOI : 10.1109/34.615450
Calculus of Variations and Harmonic Maps, 1993. ,
Viewpoint invariance for non-planar scenes, 2006. ,
DOI : 10.1109/iccv.2005.99
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.332.1397
A multiphase level set framework for image processing using the Mumford?Shah functional, International Journal of Computer Vision, vol.50, issue.3, pp.271-293, 2002. ,
DOI : 10.1023/A:1020874308076
Stereoscopic segmentation, Proceedings Eighth IEEE International Conference on Computer Vision. ICCV 2001, pp.59-66, 2001. ,
DOI : 10.1109/ICCV.2001.937499
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.23.283
Stereoscopic segmentation, Proceedings Eighth IEEE International Conference on Computer Vision. ICCV 2001, pp.31-43, 2003. ,
Estimation of Arbitrary Albedo and Shape from Shading for Symmetric Objects, Procedings of the British Machine Vision Conference 2002, pp.728-736, 2002. ,
DOI : 10.5244/C.16.71
The KGBR viewpoint???lighting ambiguity, Journal of the Optical Society of America A, vol.20, issue.1, pp.24-31, 2003. ,
DOI : 10.1364/JOSAA.20.000024
Determining generative models of objects under varying illumination: shape and albedo from multiple images using svd and integrability, International Journal of Computer Vision, vol.35, issue.3, pp.203-222, 1999. ,
DOI : 10.1023/A:1008180726317
Shape-from-shading: a survey, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.21, issue.8, pp.690-706, 1999. ,
DOI : 10.1109/34.784284
Estimation of illuminant direction, albedo, and shape from shading, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.13, issue.7, pp.680-702, 1991. ,
DOI : 10.1109/34.85658
