Preprints, Working Papers, ...
On some difficulties with a posterior probability approximation technique
Abstract : In Scott (2002) and Congdon (2006), a new method is advanced to compute posterior probabilities of models under consideration. It is based solely on MCMC outputs restricted to single models, i.e., it is bypassing reversible jump and other model exploration techniques. While it is indeed possible to approximate posterior probabilities based solely on MCMC outputs from single models, as demonstrated by Gelfand and Dey (1994) and Bartolucci et al. (2006), we show that the proposals of Scott (2002) and Congdon (2006) are biased and advance several arguments towards this thesis, the primary one being the confusion between model-based posteriors and joint pseudo-posteriors.
Document type :
Complete list of metadata
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/inria-00260507
Contributor : Jean-Michel Marin Connect in order to contact the contributor
Submitted on : Tuesday, March 4, 2008 - 1:33:20 PM
Last modification on : Friday, August 5, 2022 - 2:49:41 PM
Long-term archiving on: : Friday, September 28, 2012 - 10:35:49 AM
File
robert-marin.pdf
Identifiers
  • HAL Id : inria-00260507, version 1
Citation
Christian P. Robert, Jean-Michel Marin. On some difficulties with a posterior probability approximation technique. 2008. ⟨inria-00260507⟩
Share
Metrics
Record views
110
Files downloads
155
