New interface
Conference papers
Visualization of Point-Based Surfaces with Locally Reconstructed Subdivision Surfaces
Tamy Boubekeur 1, 2 Patrick Reuter 1, 2 Christophe Schlick 1, 2
1 IPARLA - Visualization and manipulation of complex data on wireless mobile devices
INRIA Futurs, Université Sciences et Technologies - Bordeaux 1, École Nationale Supérieure d'Électronique, Informatique et Radiocommunications de Bordeaux (ENSEIRB), CNRS - Centre National de la Recherche Scientifique : UMR5800
Abstract : Point-based surfaces (i.e. surfaces represented by discrete point sets which are either directly obtained by current 3D acquisition devices or converted from other surface representations) are well designed for multiresolution storage and transmission of complex objects. Unfortunately, visualization of point-based surfaces requires to develop specific rendering techniques (e.g. splatting) as point sets are not well adapted to existing graphics hardware which are optimized for polygonal meshes. In this paper, we propose an efficient reconstruction and visualization technique of point-based surfaces that takes full benefit from the whole optimized pipeline implemented in graphics hardware. The basic idea is to generate a set of independent meshes using a local 2D Delaunay triangulation of the point set. These meshes are then glued together to get a ``visual continuity'' by using a subdivision process.
Document type :
Conference papers
Complete list of metadata
Cited literature [33 references]  Display  Hide  Download
https://hal.inria.fr/inria-00260839
Contributor : Tamy Boubekeur Connect in order to contact the contributor
Submitted on : Wednesday, March 5, 2008 - 4:30:26 PM
Last modification on : Saturday, June 25, 2022 - 8:29:53 PM
Long-term archiving on: : Thursday, May 20, 2010 - 11:57:26 PM
File
VisPBSSubSurfRec.pdf
Identifiers
  • HAL Id : inria-00260839, version 1
Collections
Citation
Tamy Boubekeur, Patrick Reuter, Christophe Schlick. Visualization of Point-Based Surfaces with Locally Reconstructed Subdivision Surfaces. IEEE Shape Modeling International, Jun 2005, Boston, United States. ⟨inria-00260839⟩
Share
Metrics
Record views
227
Files downloads
320
