On the Topology of the Restricted Delaunay Triangulation and Witness Complex in Higher Dimensions. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2006
It is a well-known fact that, under mild sampling conditions, the restricted Delaunay triangulation provides good topological approximations of 1- and 2-manifolds. We show that this is not the case for higher-dimensional manifolds, even under stronger sampling conditions. Specifically, it is not true that, for any compact closed submanifold S of R^n, and any sufficiently dense uniform sampling L of S, the Delaunay triangulation of L restricted to S is homeomorphic to S, or even homotopy equivalent to S. Besides, it is not true either that, for any sufficiently dense set W of witnesses, the witness complex of L relative to W coincides with the restricted Delaunay triangulation of L.
o-trdwchd-06.pdf (169.05 Ko) Télécharger le fichier
inria-00260861 , version 1 (06-03-2008)
inria-00260861 , version 2 (09-03-2008)
  • HAL Id : inria-00260861 , version 1
Steve Oudot. On the Topology of the Restricted Delaunay Triangulation and Witness Complex in Higher Dimensions.. 2006. ⟨inria-00260861v1⟩
54 Consultations
118 Téléchargements
