On normals and projection operators for surfaces defined by point sets, Symposium on Point-based Graphics, 2004. ,
Point set surfaces, Proceedings of IEEE Visualization, 2001. ,
Computing and rendering point set surfaces, IEEE Transactions on Visualization and Computer Graphics, vol.9, issue.1, 2003. ,
Interactive boolean operations on surfel-bounded solids, Proceedings of ACM SIG- GRAPH, 2003. ,
Point-based computer graphics, ACM SIGGRAPH Course Notes, 2004. ,
Defining point-set surfaces, Proceedings of ACM SIGGRAPH, 2004. ,
The domain of a point set surfaces, Symposium on Point-based Graphics, 2004. ,
Meshless methods: An c The Eurographics Association, 2005. ,
Surface Reconstruction with Enriched Reproducing Kernel Particle Approximation overview and recent developments, Computer Methods in Applied Mechanics and Engineering, vol.139, 1996. ,
DOI : 10.1109/pbg.2005.194068
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.220.3124
An implicit surface polygonizer, Graphics Gems IV, 1994. ,
Progressive point set surfaces, ACM Transactions on Computer Graphics, vol.22, issue.4, 2003. ,
Robust moving least-squares fitting with sharp features, Proceedings of ACM SIGGRAPH, 2005. ,
Feature extraction from point clouds, Proceedings of the 10 th International Meshing Roundtable, 2001. ,
A survey of pointbased techniques in computer graphics, Computers & Graphics, vol.28, p.6, 2004. ,
Feature-sensitive surface extraction from volume data, Proceedings of ACM SIG- GRAPH, 2001. ,
The approximation power of moving leastsquares, Mathematics of Computation, vol.67, p.224, 1998. ,
Mesh-independent surface interpolation, 4th International Conference on Curves and Surfaces, 1999. ,
Mesh-independent surface interpolation, Geometric Modeling for Scientific Visualization, 2003. ,
Reproducing kernel particle methods for structural dynamics, Int. J. Numer. Meths. Eng, vol.38, pp.1655-1679, 1995. ,
Surfaces generated by moving least squares methods, Mathematics of Computation, vol.37, p.155, 1981. ,
Point based animation of elastic, plastic and melting objects, Symposium on Computer Animation, 2004. ,
Moving least squares multiresolution surface approximation, Proceedings of SIBGRAPI, 2003. ,
Dual/primal mesh optimization for polygonized implicit surfaces, Journal of Computing and Information Science in Engineering, vol.2, p.4, 2002. ,
Multi-level partition of unity implicits, ACM Transactions on Graphics (TOG), vol.22, pp.3-463, 2003. ,
Multi-scale feature extraction on point-sampled models, Proceedings of Eurographics, 2003. ,
Shape modeling with point-sampled geometry, Proceedings of ACM SIGGRAPH, 2003. ,
Interpolating and approximating implicit surfaces from polygon soup, Proceedings of ACM SIGGRAPH, 2004. ,
Post-processing of scanned 3D surface data, Symposium on Point- Based Graphics, 2004. ,
CSG tree rendering of point-sampled objects, Proceedings of Pacific Graphics, 2004. ,
Touch-based haptics for interactive editing on point set surfaces, IEEE Computer Graphics and Applications, vol.24, issue.6, 2004. ,
Pointshop 3D: An interactive system for point-based surface editing, Proceedings of ACM SIGGRAPH, 2002. ,
