Complexity of the Delaunay Triangulation of Points on Polyhedral Surfaces, Discrete and Computational Geometry, vol.30, issue.3, 2001. ,
DOI : 10.1007/s00454-003-2824-x
URL : https://hal.archives-ouvertes.fr/inria-00072355
Point set surfaces, Proceedings of IEEE Visualization, 2001. ,
The power crust, Proceedings of the sixth ACM symposium on Solid modeling and applications , SMA '01, 2001. ,
DOI : 10.1145/376957.376986
Smooth surface reconstruction via natural neighbour interpolation of distance functions, Proceedings of the sixteenth annual symposium on Computational geometry, 2000. ,
URL : https://hal.archives-ouvertes.fr/inria-00072662
Active Contours, 1998. ,
DOI : 10.1007/978-1-4471-1555-7
Polygonization of implicit surfaces, Computer Aided Geometric Design, vol.5, issue.4, 1988. ,
DOI : 10.1016/0167-8396(88)90013-1
An Implicit Surface Polygonizer, Graphics Gems IV, 1994. ,
DOI : 10.1016/B978-0-12-336156-1.50040-9
Piecewise smooth subdivision surfaces with normal control, Proceedings of the 27th annual conference on Computer graphics and interactive techniques , SIGGRAPH '00, 2000. ,
DOI : 10.1145/344779.344841
High quality splatting on today's gpu, Proceedings of the Symposium on Point Based Graphics, 2005. ,
DOI : 10.1109/pbg.2005.194059
A greedy Delaunay-based surface reconstruction algorithm, The Visual Computer, vol.20, issue.1, 2002. ,
DOI : 10.1007/s00371-003-0217-z
URL : https://hal.archives-ouvertes.fr/inria-00072024
Tight cocone, Proceedings of the eighth ACM symposium on Solid modeling and applications , SM '03, 2003. ,
DOI : 10.1145/781606.781627
Delaunay based shape reconstruction from large data, Proceedings of the IEEE symposium on parallel and large-data visualization and graphics, 2001. ,
Intelligent balloon, Proceedings of the sixth ACM symposium on Solid modeling and applications , SMA '01, 2001. ,
DOI : 10.1145/376957.376963
A multidisciplinary survey of visibility, ACM Siggraph course notes Visibility, Problems, Techniques, and Applications, 2000. ,
Shape Reconstruction from 3D and 2D Data Using PDE-Based Deformable Surfaces, 2004. ,
DOI : 10.1007/978-3-540-24672-5_19
Robust moving least-squares fitting with sharp features, Proceedings of ACM SIGGRAPH, 2005. ,
DOI : 10.1145/1186822.1073227
Smooth interpolation of large sets of scattered data, International Journal for Numerical Methods in Engineering, vol.II, issue.11, 1980. ,
DOI : 10.1002/nme.1620151110
A fast and efficient projection based approach for surface reconstruction . nternational Journal of High Performance Computer Graphics, Multimedia and Visualization, 2000. ,
Surface Reconstruction based on Lower Dimensional Localized Delaunay Triangulation, Proceedings Eurographics, 2000. ,
DOI : 10.1111/1467-8659.00439
Surface reconstruction from unorganized points, ACM SIGGRAPH Computer Graphics, vol.26, issue.2, pp.71-78, 1992. ,
DOI : 10.1145/142920.134011
Mesh optimization, Proceedings of the 20th annual conference on Computer graphics and interactive techniques , SIGGRAPH '93, 1993. ,
DOI : 10.1145/166117.166119
Piecewise smooth surface reconstruction, Proceedings of the 21st annual conference on Computer graphics and interactive techniques , SIGGRAPH '94, 1994. ,
DOI : 10.1145/192161.192233
Feature sensitive surface extraction from volume data, Proceedings of the 28th annual conference on Computer graphics and interactive techniques , SIGGRAPH '01, 2001. ,
DOI : 10.1145/383259.383265
Snakes: Active contour models, International Journal of Computer Vision, vol.5, issue.6035, 1987. ,
DOI : 10.1007/BF00133570
Marching cubes: a high resolution 3d surface construction algorithm, Computer Graphics, vol.21, 1987. ,
The approximation power of moving least-squares, Mathematics of Computation, vol.67, issue.224, 1998. ,
DOI : 10.1090/S0025-5718-98-00974-0
Radial basis functions for the multivariate interpolation of large scattered data sets, Journal of Computational and Applied Mathematics, vol.140, issue.1-2, 2002. ,
DOI : 10.1016/S0377-0427(01)00485-X
Fan Clouds - An Alternative to Meshes, Proceedings of the 11th International Dagstuhl Workshop on Theoretical Foundations of Computer Vision, 2003. ,
DOI : 10.1007/3-540-36586-9_3
Dual/Primal mesh optimization for polygonized implicit surfaces, Proceedings of the seventh ACM symposium on Solid modeling and applications , SMA '02, pp.171-178, 2002. ,
DOI : 10.1145/566282.566308
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.18.9893
Multi-level partition of unity implicits, Proceedings of ACM SIGGRAPH 2003, 2003. ,
3D scattered data approximation with adaptive compactly supported radial basis functions, Proceedings Shape Modeling Applications, 2004., 2004. ,
DOI : 10.1109/SMI.2004.1314491
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.61.3544
Surface reconstruction with enriched reproducing kernel particle approximation, Proceedings Eurographics/IEEE VGTC Symposium Point-Based Graphics, 2005., pp.79-87, 2005. ,
DOI : 10.1109/PBG.2005.194068
URL : https://hal.archives-ouvertes.fr/inria-00260890
QSplat, Proceedings of the 27th annual conference on Computer graphics and interactive techniques , SIGGRAPH '00, 2000. ,
DOI : 10.1145/344779.344940
Triangulating point set surfaces with bounded error, Proceedings of the Eurographics Symposium on Geometry Processing, 2005. ,
Out-of-core algorithms for scientific visualization and computer graphics, IEEE Visualization, issue.4, 2003. ,
Interpolating and approximating implicit surfaces from polygon soup, ACM SIGGRAPH, 2004. ,
DOI : 10.1145/1186562.1015816
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.70.4924
Function Representation of Solids Reconstructed from Scattered Surface Points and Contours, Computer Graphics Forum, vol.14, issue.4, 1995. ,
DOI : 10.1111/1467-8659.1440181
Implicit surfaces that interpolate, Proceedings International Conference on Shape Modeling and Applications, 2002. ,
DOI : 10.1109/SMA.2001.923376
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.185.1925
Reconstructing multi-scale variational partition of unity implicit surfaces with attributes, Graphical Models, vol.68, issue.1, 2006. ,
DOI : 10.1016/j.gmod.2005.09.003
URL : https://hal.archives-ouvertes.fr/hal-00307959
Fast evaluation of radial basis functions: Methods based on partition of unity. Approximation Theory X: Wavelets, Splines, and Applications, 2002. ,
Surface splatting, Proceedings of the 28th annual conference on Computer graphics and interactive techniques , SIGGRAPH '01, 2001. ,
DOI : 10.1145/383259.383300
Subdivision for modeling and animation, ACM SIGGRAPH Courses Notes, 2000. ,
