The direct3d 10 system, Proc. ACM Siggraph, 2006. ,
Single resolution compression of arbitrary triangular meshes with properties, Proc. IEEE Conference on Data Compression '99, p.247, 1999. ,
Efficient high quality rendering of point sampled geometry, Proc. Eurographics workshop on Rendering, pp.53-64, 2002. ,
Geometry compression, Proc. ACM SIGGRAPH '95, pp.13-20, 1995. ,
Out-of-core compression for gigantic polygon meshes, Proceedings of SIGGRAPH'03, 2003. ,
Streaming compression of triangle meshes, Proceedings of 3rd Symposium on Geometry Processing, 2005. ,
Normal vector compression of 3d mesh model based on clustering and relative indexing, Future Gener. Comput. Syst, vol.20, pp.1241-1250, 2004. ,
High quality normal map compression, Proceedings of ACM Siggraph/Eurographics Graphics Hardware, 2006. ,
DOI : 10.1145/1283900.1283916
Hardware-compatible vertex compression using quantization and simplification, Proc. ACM SIGGRAPH/EUROGRAPHICS conference on Graphics hardware, pp.53-61, 2005. ,
Qsplat: a multiresolution point rendering system for large meshes, Proc. SIGGRAPH '00, pp.343-352, 2000. ,
Streaming qsplat: A viewer for networked visualization of large, dense models, ACM I3D, 2001. ,
Geometry coding and vrml, Proceedings of the IEEE, vol.86, pp.1228-1243, 1998. ,
DOI : 10.1109/5.687837
