Measuring the robustness of a resource allocation, IEEE Transactions on Parallel and Distributed Systems, vol.15, issue.7, pp.630-641, 2004. ,
DOI : 10.1109/TPDS.2004.24
Representing Task and Machine Heterogeneities for Heterogeneous Computing Systems, Tamkang Journal of Science and Engineering, vol.3, issue.3, pp.195-207, 2000. ,
Robust scheduling of metaprograms, Journal of Scheduling, vol.10, issue.5, pp.395-412, 2002. ,
DOI : 10.1002/jos.115
ParadisEO: A Framework for the Reusable Design of Parallel and Distributed Metaheuristics, Journal of Heuristics, vol.10, issue.3, pp.357-380, 2004. ,
DOI : 10.1023/B:HEUR.0000026900.92269.ec
The Greatest of a Finite Set of Random Variables, Operations Research, vol.9, issue.2, pp.145-162, 1961. ,
DOI : 10.1287/opre.9.2.145
PESA-II: Region-based Selection in Evolutionary Multiobjective Optimization, Proceedings of the Genetic and Evolutionary Computation Conference (GECCO-2001), pp.283-290, 2001. ,
?-Robust scheduling for single-machine systems with uncertain processing times, IIE Transactions, vol.29, issue.11, pp.977-985, 1997. ,
A Survey of Techniques for Scheduling with Uncertainty. Unpublished manuscript, 2002. ,
Slackbased Techniques for Robust Schedules, Proceedings of the Sixth European Conference on Planning (ECP-2001), pp.7-18, 2001. ,
A Fast Elitist Non-dominated Sorting Genetic Algorithm for Multi-objective Optimization: NSGA-II, IEEE Transactions on Evolutionary Computation, vol.6, issue.2, pp.182-197, 2002. ,
DOI : 10.1007/3-540-45356-3_83
Bounding the Project Completion Time Distribution in PERT Networks, Operations Research, vol.33, issue.4, pp.862-881, 1985. ,
DOI : 10.1287/opre.33.4.862
Possibility Theory: An Approach to Computerized Processing of Uncertainty, 1988. ,
Task Scheduling in Parallel and Distributed Systems, 1994. ,
A new metric for robustness with application to job scheduling, HPDC-14. Proceedings. 14th IEEE International Symposium on High Performance Distributed Computing, 2005., pp.135-143, 2005. ,
DOI : 10.1109/HPDC.2005.1520948
Fuzzy scheduling: Modelling flexible constraints vs. coping with incomplete knowledge, European Journal of Operational Research, vol.147, issue.2, pp.231-252, 2003. ,
The Linear Extension Diameter of a Poset, SIAM Journal on Discrete Mathematics, vol.12, issue.3, pp.360-373, 1999. ,
DOI : 10.1137/S0895480197326139
Experience with Graph Scheduling for Mapping Irregular Scientific Computation, First IPPS workshop on Solving Irregular Problems on Distributed Memory Machines, pp.1-8, 1995. ,
Computational complexity of PERT problems, Networks, vol.8, issue.2, pp.139-147, 1998. ,
DOI : 10.1002/net.3230180206
Robust and reactive project scheduling: a review and classification of procedures, International Journal of Production Research, vol.27, issue.8, pp.1599-1620, 2004. ,
DOI : 10.1016/0305-0548(93)90091-V
Project scheduling under uncertainty: Survey and research potentials, European Journal of Operational Research, vol.165, issue.2, pp.289-306, 2005. ,
DOI : 10.1016/j.ejor.2004.04.002
Evolutionary Optimization in Uncertain Environments???A Survey, IEEE Transactions on Evolutionary Computation, vol.9, issue.3, pp.303-3017, 2005. ,
DOI : 10.1109/TEVC.2005.846356
Conditional Monte Carlo: A Simulation Technique for Stochastic Network Analysis, Management Science, vol.18, issue.3, pp.207-217, 1971. ,
A heuristic for optimizing stochastic activity networks with applications to statistical digital circuit sizing, Optimization and Engineering, vol.20, issue.1, pp.397-430, 2007. ,
DOI : 10.1007/s11081-007-9011-5
A probabilstic upper bound on differential entropy, IEEE Transactions on Information Theory, Under revision, 2007. ,
Estimating the Execution Time Distribution for a Task Graph in a Heterogeneous Computing System, 6th IEEE Heterogeneous Computing Workshop (HCW'97), pp.172-184, 1997. ,
Bounds on scheduling algorithms for heterogeneous computing systems, Proceedings of IFIP Congress 74, pp.349-353, 1974. ,
A Computational Study on Bounding the Makespan Distribution in Stochastic Project Networks, Annals of Operations Research, vol.102, pp.1-449, 2001. ,
A dynamic matching and scheduling algorithm for heterogeneous computing systems, Proceedings Seventh Heterogeneous Computing Workshop (HCW'98), pp.57-69, 1998. ,
DOI : 10.1109/HCW.1998.666545
A static scheduling heuristic for heterogeneous processors, Proceedings of the Second International Euro- Par Conference on Parallel Processing-Volume II, pp.573-577, 1996. ,
DOI : 10.1007/BFb0024750
Convergence of evolutionary algorithms in general search spaces, Proceedings of IEEE International Conference on Evolutionary Computation, pp.50-54, 1996. ,
DOI : 10.1109/ICEC.1996.542332
Convergence properties of some multi-objective evolutionary algorithms, Proceedings of the 2000 Congress on Evolutionary Computation. CEC00 (Cat. No.00TH8512), pp.1010-1016, 2000. ,
DOI : 10.1109/CEC.2000.870756
A hybrid heuristic for DAG scheduling on heterogeneous systems, 18th International Parallel and Distributed Processing Symposium, 2004. Proceedings., 2004. ,
DOI : 10.1109/IPDPS.2004.1303065
Local-Global scheduling interactions, 2008. ,
A Stochastic Approach to Measuring the Robustness of Resource Allocations in Distributed Systems, 2006 International Conference on Parallel Processing (ICPP'06), pp.459-470, 2006. ,
DOI : 10.1109/ICPP.2006.14
Robust task scheduling in non-deterministic heterogeneous computing systems, 2006 IEEE International Conference on Cluster Computing, pp.1-10, 2006. ,
DOI : 10.1109/CLUSTR.2006.311868
A compile-time scheduling heuristic for interconnection-constrained heterogeneous processor architectures, IEEE Transactions on Parallel and Distributed Systems, vol.4, issue.2, pp.175-187, 1993. ,
DOI : 10.1109/71.207593
A standard task graph set for fair evaluation of multiprocessor scheduling algorithms, Journal of Scheduling, vol.70, issue.5, pp.379-394, 2002. ,
DOI : 10.1002/jos.116
Performance-effective and low-complexity task scheduling for heterogeneous computing, IEEE Transactions on Parallel and Distributed Systems, vol.13, issue.3, pp.260-274, 2002. ,
DOI : 10.1109/71.993206
Monte Carlo Methods and the PERT Problem, Operations Research, vol.11, issue.5, pp.839-860, 1963. ,
Task Matching and Scheduling in Heterogeneous Computing Environments Using a Genetic-Algorithm-Based Approach, Journal of Parallel and Distributed Computing, vol.47, issue.1, pp.8-22, 1997. ,
DOI : 10.1006/jpdc.1997.1392
Optimal Factory Scheduling Using Stochastic Dominance A*, 13th National Conference on Artificial Intelligence, p.1416, 1996. ,
Indicator-Based Selection in Multiobjective Search, Conference on Parallel Problem Solving from Nature (PPSN VIII), pp.832-842, 2004. ,
DOI : 10.1007/978-3-540-30217-9_84
SPEA2: Improving the Strength Pareto Evolutionary Algorithm for Multiobjective Optimization, Evolutionary Methods for Design Optimization and Control with Applications to Industrial Problems, pp.95-100, 2001. ,
Performance assessment of multiobjective optimizers: an analysis and review, IEEE Transactions on Evolutionary Computation, vol.7, issue.2, pp.117-132, 2003. ,
DOI : 10.1109/TEVC.2003.810758
Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès ,
