New interface
Conference papers
The Alignment Between 3-D Data and Articulated Shapes with Bending Surfaces
Guillaume Dewaele 1 Frédéric Devernay 1 Radu Horaud 1 Florence Forbes 2
1 MOVI - Modeling, localization, recognition and interpretation in computer vision
GRAVIR - IMAG - Laboratoire d'informatique GRAphique, VIsion et Robotique de Grenoble, Inria Grenoble - Rhône-Alpes, CNRS - Centre National de la Recherche Scientifique : FR71
Abstract : In this paper we address the problem of aligning 3-D data with articulated shapes. This problem resides at the core of many motion tracking methods with applications in human motion capture, action recognition, medical-image analysis, etc. We describe an articulated and bending surface representation well suited for this task as well as a method which aligns (or registers) such a surface to 3-D data. Articulated objects, e.g., humans and animals, are covered with clothes and skin which may be seen as textured surfaces. These surfaces are both articulated and deformable and one realistic way to model them is to assume that they bend in the neighborhood of the shape's joints. We will introduce a surface-bending model as a function of the articulated-motion parameters. This combined articulated-motion and surface-bending model better predicts the observed phenomena in the data and therefore is well suited for surface registration. Given a set of sparse 3-D data (gathered with a stereo camera pair) and a textured, articulated, and bending surface, we describe a register-and-fit method that proceeds as follows. First, the data-to-surface registration problem is formalized as a classifier and is carried out using an EM algorithm. Second, the data-to-surface fitting problem is carried out by minimizing the distance from the registered data points to the surface over the joint variables. In order to illustrate the method we applied it to the problem of hand tracking. A hand model with 27 degrees of freedom is successfully registered and fitted to a sequence of 3-D data points gathered with a stereo camera pair.
Document type :
Conference papers
Complete list of metadata
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/inria-00262288
Contributor : Frédéric Devernay Connect in order to contact the contributor
Submitted on : Tuesday, March 11, 2008 - 12:21:08 PM
Last modification on : Wednesday, May 4, 2022 - 12:12:03 PM
Long-term archiving on: : Friday, May 21, 2010 - 12:09:45 AM
File
eccv06.pdf
Publisher files allowed on an open archive
Identifiers
Collections
Citation
Guillaume Dewaele, Frédéric Devernay, Radu Horaud, Florence Forbes. The Alignment Between 3-D Data and Articulated Shapes with Bending Surfaces. European Conference on Computer Vision, May 2006, Graz, Austria. pp.578-591, ⟨10.1007/11744078_45⟩. ⟨inria-00262288⟩
Share
Metrics
Record views
214
Files downloads
179
