New interface
Conference papers
Temporal tracking of 3D coronary arteries in projection angiograms
Abstract : A method for 3D temporal tracking of a 3D coronary tree model through a sequence of biplane cineangiography images has been developed. A registration framework is formulated in which the coronary tree centerline model deforms in an external potential ¯eld de¯ned by a multiscale analysis response map computed from the angiogram images. To constrain the procedure and to improve convergence, a set of three motion models is hierarchically used: a 3D rigid-body transformation, a 3D a±ne transformation, and a 3D B-spline deformation ¯eld. This 3D motion tracking approach has signi¯cant advantages over 2D methods: (1) coherent deformation of a single 3D coronary reconstruction preserves the topology of the arterial tree; (2) constraints on arterial length and regularity, which lack meaning in 2D projection space, are directly applicable in 3D; and (3) tracking arterial segments through occlusions and crossings in the projection images is simpli¯ed with knowledge of the 3D relationship of the arteries. The method has been applied to patient data and results are presented.
Complete list of metadata
https://hal.inria.fr/inria-00262390
Contributor : Frédéric Devernay Connect in order to contact the contributor
Submitted on : Tuesday, March 11, 2008 - 3:59:20 PM
Last modification on : Friday, November 18, 2022 - 9:23:30 AM
Long-term archiving on: : Friday, May 21, 2010 - 12:11:17 AM
File
SDCM02.pdf
Publisher files allowed on an open archive
Identifiers
Collections
Citation
Guy Shechter, Frédéric Devernay, Ève Coste-Manière, Elliot R. Mcveigh. Temporal tracking of 3D coronary arteries in projection angiograms. Medical Imaging, SPIE, 2002, San Diego, United States. ⟨10.1117/12.467204⟩. ⟨inria-00262390⟩
Share
Metrics
Record views
220
Files downloads
221
