On the possibility and impossibility of achieving clock synchronization, Journal of Computer and System Sciences, vol.32, issue.2, pp.230-250, 1986. ,
DOI : 10.1016/0022-0000(86)90028-0
An overview of clock synchronization, LNCS, vol.448, pp.84-96, 1990. ,
DOI : 10.1007/BFb0042327
Understanding protocols for Byzantine clock synchronization, 1987. ,
Performance evaluation of clock synchronisation algorithms, 1998. ,
Special Issue on The Challenge of Global Time in Large-Scale Distributed Real-Time Systems, J. Real-Time Systems, vol.12, pp.1-3, 1997. ,
The accuracy of the clock synchronization achieved by TEMPO in Berkeley UNIX 4.3BSD, IEEE Transactions on Software Engineering, vol.15, issue.7, pp.847-853, 1989. ,
DOI : 10.1109/32.29484
Clock synchronization in the presence of omission and performance failures, and joins, Proc. of the 15th Int'l Symposium on Fault Tolerant Computing, 1986. ,
Fault-tolerant clcok synchronization, Proceedings of the 3rd ACM Symposium on Principles of Distributed Computing, pp.89-102, 1984. ,
Optimal clock synchronization, Journal of the ACM, vol.34, issue.3, pp.626-645, 1987. ,
DOI : 10.1145/28869.28876
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.13.6542
A new fault-tolerant algorithm for clock synchronization, Information and Computation, vol.77, issue.1, pp.1-36, 1988. ,
DOI : 10.1016/0890-5401(88)90043-0
Linear Time Byzantine Self-Stabilizing Clock Synchronization, Proceedings of the 7th International Conference on Principles of Distributed Systems, pp.7-19, 2003. ,
DOI : 10.1007/978-3-540-27860-3_4
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.3.4581
Self-stabilizing clock synchronization in the presence of Byzantine faults, Journal of the ACM, vol.51, issue.5, pp.780-799, 2004. ,
DOI : 10.1145/1017460.1017463
Designing Modular Services in the Scattered Byzantine Failure Model, Third International Symposium on Parallel and Distributed Computing/Third International Workshop on Algorithms, Models and Tools for Parallel Computing on Heterogeneous Networks, pp.262-269, 2004. ,
DOI : 10.1109/ISPDC.2004.18
Clock synchronization with faults and recoveries (extended abstract), Proceedings of the nineteenth annual ACM symposium on Principles of distributed computing , PODC '00, pp.133-142, 2000. ,
DOI : 10.1145/343477.343534
The Byzantine Generals Problem, ACM Transactions on Programming Languages and Systems, vol.4, issue.3, pp.382-401, 1982. ,
DOI : 10.1145/357172.357176
Synchronizing clocks in the presence of faults, Journal of the ACM, vol.32, issue.1, pp.52-78, 1985. ,
DOI : 10.1145/2455.2457
Clock Synchronization in the Byzantine-Recovery Failure Model, 2007. ,
DOI : 10.1007/978-3-540-77096-1_7
URL : https://hal.archives-ouvertes.fr/inria-00264219
Simulating authenticated broadcasts to derive simple fault-tolerant algorithms, Distributed Computing, vol.21, issue.2, pp.80-94, 1987. ,
DOI : 10.1007/BF01667080
URL : http://ecommons.cornell.edu/bitstream/1813/6462/1/84-623.pdf
Booting clock synchronization in partially synchronous systems with hybrid process and link failures, Distributed Computing, vol.290, issue.3, pp.115-140, 2007. ,
DOI : 10.1007/s00446-007-0026-0
An optimal internal clock synchronization algorithm, COMPASS '95 Proceedings of the Tenth Annual Conference on Computer Assurance Systems Integrity, Software Safety and Process Security', pp.187-196, 1995. ,
DOI : 10.1109/CMPASS.1995.521898
An upper and lower bound for clock synchronization, Information and Control, vol.62, issue.2-3, pp.190-240, 1984. ,
DOI : 10.1016/S0019-9958(84)80033-9
