Extracting a data flow analyser in constructive logic, Theoretical Computer Science, vol.342, issue.1, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00564633
Non-null References by Default in Java: Alleviating the Nullity Annotation Burden, Proceedings of European Conference on Object- Oriented Programming ,
DOI : 10.1007/978-3-540-73589-2_12
Propagation of JML non-null annotations in Java programs, Proceedings of the 4th international symposium on Principles and practice of programming in Java , PPPJ '06 ,
DOI : 10.1145/1168054.1168073
Esp: path-sensitive program verification in polynomial time, Proceedings of the ACM SIGPLAN Conference on Programming language design and implementation (PLDI'02) ,
Pluggable non-null types for Java, Extensible Compiler Construction, chapter, 2006. ,
Declaring and checking non-null types in an object-oriented language, Proceedings of Conference on Object-Oriented Programming Systems, Languages, and Applications (OOPSLA'03) ,
Establishing object invariants with delayed types, OOPSLA '07: Proceedings of the 22nd ACM conference on Object Oriented Programming Systems and Applications ,
Houdini, an annotation assistant for, Proceedings of International Symposium of Formal Methods Europe (FME'01) ,
A formal framework for the java bytecode language and verifier, Proceedings of the 14th ACM conference on Object-oriented programming, systems, languages, and applications (OOPSLA '99) ,
Finding more null pointer bugs, but not too many, Proceedings of the 7th ACM SIGPLAN-SIGSOFT workshop on Program analysis for software tools and engineering , PASTE '07 ,
DOI : 10.1145/1251535.1251537
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.93.1704
Evaluating and tuning a static analysis to find null pointer bugs, SIGSOFT Softw. Eng. Notes, issue.1, p.31, 2006. ,
Effective null pointer check elimination utilizing hardware trap, SIGPLAN Not, vol.35, issue.11, 2000. ,
We denote in this proof L (m, i) by L and T (m, i) by T . We propose an induction on e ,
L(x) We distinguish two cases. ? If L (x) = Raw(super(C)), as Raw(C) Raw(super, Raw(C) L(x) holds ? otherwise L (x) L(x) holds by definition of L ,
Raw(C) and class(f ) C, then ?, L e .f : MayBeNull and ,
Raw(C) and C class(f ), then ?, L e .f : ? [f ] and ,
The analysis gives us ,
We do a case analysis on P m [i] ,
m,i),L (m,i) holds. We distinguish two cases. ? If e = MayBeNull, then it contradicts ?, L e : ? . So e = MayBeNull, so safe expr (e), L (m,i) holds ,
? means that there exists L and F such that ,
we must show that safe expr (e) C,H ,T (m,i),L (m,i) holds. By hypothesis, ?, L e : ? , so from Lemma 26 the property holds ,
we must show that L(m, i)(x) = MayBeNull and safe expr (e) C,H ,T (m,i),L (m,i) hold. By hypothesis, L(m, i)(x) = MayBeNull and ?, L e : ? , so, pp.55-81 ,
e j ), we must show that ?j, safe expr (e j ) class(m),H ,T (m,i),L (m,i) By hypothesis, ?i, ?? i , ?, L e i : ? i ), so, from Lemma 26, the property holds ,
we must show that L (m, i)(x) = MayBeNull and f orallj, safe expr (e j ) class(m),H ,T (m,i),L (m,i) By hypothesis, (?i, ?, L e i : ? i ) and if ? [lookup(ms)] = [? ]? ? void then ?, L x : if ? ? Val then ? else Raw(super(C )) and ? = MayBeNull ,
If P is LF-typable w.r.t. ?, L, F, then there exists, Theorem 5 ,
Forall m and m , let ? ,
class(m ) M (m )[this] holds ,
