HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Analysis of an M/G/1 queue with repeated inhomogeneous vacations -- Application to IEEE 802.16e power saving
Sara Alouf 1, * Eitan Altman 1 Amar Prakash Azad 1
* Corresponding author
1 MAESTRO - Models for the performance analysis and the control of networks
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : This report presents a method for analyzing a queueing model with repeated inhomogeneous vacations. At the end of a vacation, the server goes on another vacation, possibly with a different probability distribution, if during the previous vacation there have been no arrivals. In order to get an insight on the influence of parameters on the performance, we choose to study a simple M/G/1 queue (Poisson arrivals and general independent service times) which has the advantage of being tractable analytically. The theoretical model is applied to the problem of power saving for mobile devices in which the sleep durations of a device correspond to the vacations of the server. Various system performance metrics such as the frame response time and the economy of energy are derived. A constrained optimization problem is formulated to maximize the economy of energy achieved in power save mode, with constraints as QoS conditions to be met. An illustration of the proposed methods is shown with a WiMAX system scenario to obtain design parameters for better performance. Our analysis allows us not only to optimize the system parameters for given traffic intensity but also to propose parameters that provide the best performance under worst case conditions.
Complete list of metadata
Cited literature [13 references]  Display  Hide  Download
https://hal.inria.fr/inria-00266552
Contributor : Sara Alouf Connect in order to contact the contributor
Submitted on : Wednesday, April 2, 2008 - 4:34:33 PM
Last modification on : Thursday, January 20, 2022 - 5:28:18 PM
Long-term archiving on: : Thursday, September 23, 2010 - 4:25:17 PM
RR-6488.pdf
Identifiers
  • HAL Id : inria-00266552, version 3
Collections
Relations
Citation
Sara Alouf, Eitan Altman, Amar Prakash Azad. Analysis of an M/G/1 queue with repeated inhomogeneous vacations -- Application to IEEE 802.16e power saving. [Research Report] RR-6488, INRIA. 2008, pp.31. ⟨inria-00266552v3⟩
Share
Metrics
Record views
174
Files downloads
212
