Passivity-based tracking control of multiconstraint complementarity Lagrangian systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
In this study one considers the tracking control problem of a class of nonsmooth fully actuated Lagrangian systems subject to frictionless unilateral constraints. A passivity-based switching controller that guarantees some stability properties of the closed-loop system is designed. A particular attention is paid to transition (impacting) and detachment phases of motion. This paper extends previous works on the topic as it considers multiconstraint n-degree-of-freedom systems.
Automatique
Raport_M_B.pdf (617.82 Ko) Télécharger le fichier
inria-00266810 , version 1 (25-03-2008)
inria-00266810 , version 2 (29-04-2008)
  • HAL Id : inria-00266810 , version 1
Irinel-Constantin Morarescu, Bernard Brogliato. Passivity-based tracking control of multiconstraint complementarity Lagrangian systems. [Research Report] RR-6483, 2008, pp.35. ⟨inria-00266810v1⟩
208 Consultations
294 Téléchargements
