Compensated Horner algorithm in K times the working precision - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Nicolas Louvet
We introduce an algorithm to evaluate a polynomial with floating point coefficients as accurately as the Horner scheme performed in K times the working precision, for K an arbitrary integer. The principle is to iterate the error-free transformation of the compensated Horner algorithm and to accurately sum the final decomposition. We prove this accuracy property with an apriori error analysis. We illustrate its practical efficiency with numerical experiments on significant environments and IEEE-754 arithmetic. Comparing to existing alternatives we conclude that this K-times compensated algorithm is competitive for K up to 4, i.e. up to 212 mantissa bits.
LaLo07.pdf (451.1 Ko) Télécharger le fichier
inria-00267077 , version 1 (26-03-2008)
  • HAL Id : inria-00267077 , version 1
Philippe Langlois, Nicolas Louvet. Compensated Horner algorithm in K times the working precision. [Research Report] 2008. ⟨inria-00267077⟩
267 Consultations
145 Téléchargements
