Testing Statistical Hypotheses About Ergodic Processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
We address three problems of statistical analysis of time series: goodness-of-fit (or identity) testing, process discrimination, and the change point problem. For each of the problems we construct a test that is asymptotically accurate for the case when the data is generated by stationary ergodic processes. All problems are solved in a similar way by using empirical estimates of the distributional distance between the processes.
3s.pdf (120.57 Ko) Télécharger le fichier
inria-00269249 , version 1 (03-04-2008)
inria-00269249 , version 2 (11-04-2008)
inria-00269249 , version 3 (06-07-2009)
inria-00269249 , version 4 (24-03-2012)
  • HAL Id : inria-00269249 , version 1
  • ARXIV : 0804.0510
Daniil Ryabko, Boris Ryabko. Testing Statistical Hypotheses About Ergodic Processes. [Research Report] 2008. ⟨inria-00269249v1⟩
176 Consultations
302 Téléchargements
