A Simple Modification in CMA-ES Achieving Linear Time and Space Complexity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
This report proposes a simple modification of the Covariance Matrix Adaptation Evolution Strategy (CMA-ES) for high dimensional objective functions that reduces the internal time and space complexity from quadratic to linear. The covariance matrix is constrained to be diagonal and the resulting algorithm, sep-CMA-ES, samples each coordinate independently. Because the model complexity is reduced, the learning rate for the covariance matrix can be increased. Consequently, on essentially separable functions, sep-CMA-ES significantly outperforms CMA-ES. For dimension larger than 100, even on the non-separable Rosenbrock function, the sep-CMA-ES needs fewer function evaluations than CMA-ES.
sepCMA_techreport.pdf (443.03 Ko) Télécharger le fichier
inria-00270901 , version 1 (07-04-2008)
inria-00270901 , version 2 (08-04-2008)
inria-00270901 , version 3 (14-04-2008)
inria-00270901 , version 4 (30-06-2008)
  • HAL Id : inria-00270901 , version 1
Raymond Ros, Nikolaus Hansen. A Simple Modification in CMA-ES Achieving Linear Time and Space Complexity. [Research Report] 2008. ⟨inria-00270901v1⟩
361 Consultations
2163 Téléchargements
