radiation of flame combustion, Inverse Problems in Science and Engineering, vol.2471, issue.3, pp.219-240, 2005. ,
DOI : 10.1016/S0735-1933(00)00145-7
Automatic differentiation in C++ using expression templates and. application to a flow control problem, Computing and Visualization in Science, vol.3, issue.4, pp.197-208, 2001. ,
DOI : 10.1007/s007910000048
Sensitivity Analysis of Turbulence Models Using Automatic Differentiation, SIAM Journal on Scientific Computing, vol.26, issue.2, pp.510-522, 2004. ,
DOI : 10.1137/S1064827503426723
Mixed and Hybrid Finite Element Methods, 1991. ,
DOI : 10.1007/978-1-4612-3172-1
A Comparative Review of Sensitivity and Uncertainty Analysis of Large-Scale Systems - II: Statistical Methods, Nuclear Science and Engineering, vol.147, issue.3, pp.204-217, 2004. ,
DOI : 10.13182/04-54CR
Linearized inversion of data of multi-offset data for vertically inhomogeneous background, Journal of Inverse and Ill-Posed Problems, pp.453-484, 1998. ,
DOI : 10.1515/jiip.1998.6.5.453
Analyse de sensibilité et estimation de paramètres de transport pour uné equation de diffusion, approche parétatparétat adjoint, 2004. ,
Karhunen-Loe??ve expansion with reference to singular-value decomposition and separation of variables, IEE Proceedings D Control Theory and Applications, vol.127, issue.5, pp.204-206, 1980. ,
DOI : 10.1049/ip-d.1980.0034
On the relationships between SVD, KLT and PCA, Pattern Recognition, vol.14, issue.1-6, pp.375-381, 1981. ,
DOI : 10.1016/0031-3203(81)90082-0
Achieving logarithmic growth of temporal and spatial complexity in reverse automatic differentiation, Optimization Methods and Software, vol.1, issue.1, pp.35-54, 1992. ,
DOI : 10.1080/10556789208805505
Evaluating Derevatives: Principles and Techniques of Algorithmic Differentiation, Frontiers in Applied Mathematics. SIAM, 2000. ,
ADOL-C: A package for the automatic differentiation of algorithms written in C/C++. documentation for ADOL-C, version 1.10, 2005. ,
Algorithm 799: revolve: an implementation of checkpointing for the reverse or adjoint mode of computational differentiation, ACM Transactions on Mathematical Software, vol.26, issue.1, pp.19-45, 2000. ,
DOI : 10.1145/347837.347846
Latin hypercube sampling and the propagation of uncertainty in analyses of complex systems, 2002. ,
Sensitivity Analysis, chapter 6 Wiley series in probability and statistics, 2000. ,
Topics in matrix analysis, 1991. ,
DOI : 10.1017/CBO9780511840371
A comparative review of sensitivity and uncertainty analysis of large-scale systems?i: Deterministic methods, Nuclear Science and Engineering, vol.147, pp.189-203, 2004. ,
Wavelengths of earth structures that can be resolved from seismic reflection data, GEOPHYSICS, vol.54, issue.7, pp.906-910, 1989. ,
DOI : 10.1190/1.1442719
URL : https://hal.archives-ouvertes.fr/hal-01113158
Application of a coupled adjoint sensitivity and kriging approach to calibrate a groundwater flow model, Water Resources Research, vol.28, pp.1543-1569, 1992. ,
Numerical methods in sensitivity analysis and shape optimization, Birkäuser, 2003. ,
DOI : 10.1007/978-1-4612-0069-7
Domain decomposition methods in computational mechanics, Computational Mechanics Advances, vol.1, issue.2, 1994. ,
PROPER ORTHOGONAL DECOMPOSITION AND ITS APPLICATIONS???PART I: THEORY, Journal of Sound and Vibration, vol.252, issue.3, pp.527-544, 2002. ,
DOI : 10.1006/jsvi.2001.4041
Analyse de sensibilité déterministe pour la simulation numérique du transfert de contaminants, 2007. ,
Simulation multidomaine d'unécoulementunécoulement autour d'un site de stockage de déchets, 2004. ,
Mixed finite elements in ?3, Numerische Mathematik, vol.12, issue.3, pp.315-341, 1980. ,
DOI : 10.1007/BF01396415
Sensitivity analysis of digital flight control systems using singular-value concepts, Journal of Guidance, Control, and Dynamics, vol.12, issue.3, pp.297-303, 1989. ,
DOI : 10.2514/3.20408
A mixed finite element method for second order elliptic problems, Mathematical Aspects of Finite Element Methods, number 606 in Lecture Notes in Mathematics, pp.292-315, 1977. ,
Mixed and hybrid methods Handbook of Numerical Analysis, volume II, 1991. ,
Estimation of the Sensitivity of linear and nonlinear algebraic problems, Linear Algebra and its Applications, vol.153, pp.1-34, 1991. ,
DOI : 10.1016/0024-3795(91)90207-D
Quelques méthodes numériques robustes pour l'´ ecoulement et le transport en milieu poreux, 2007. ,
A composite mixed finite element for general hexahedral grids, SISC, 2008. ,
On the Early History of the Singular Value Decomposition, SIAM Review, vol.35, issue.4, pp.551-566, 1993. ,
DOI : 10.1137/1035134
A non-parametric approach for linear system identification using principal component analysis, Mechanical Systems and Signal Processing, pp.1576-1600, 2007. ,
DOI : 10.1016/j.ymssp.2006.07.005
10 3.5.1 The adjoint state method, 10 3.5.2 Assembling the Jacobian matrix row by row . . . . . . . . . . . . . . . . . . 11 ,
16 5.1.1 The computational domain, p.17 ,
18 5.3.1 Interpretation of the SVD results ,
