Analytical Solution for Wave Propagation in Stratified Acoustic/Porous Media. Part I: the 2D Case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
We are interested in the modeling of wave propagation in an infinite bilayered acoustic/poroelastic media. We consider the biphasic Biot's model in the poroelastic layer. This first part is devoted to the calculation of analytical solution in two dimensions, thanks to Cagniard de Hoop method. The solution is validated through comparison with solutions obtained by a numerical code. In the second part we'll consider the 3D case.
acousporo.pdf (329.52 Ko) Télécharger le fichier
inria-00274136 , version 1 (17-04-2008)
inria-00274136 , version 2 (21-04-2008)
inria-00274136 , version 3 (28-07-2008)
  • HAL Id : inria-00274136 , version 1
Julien Diaz, Abdelaâziz Ezziani. Analytical Solution for Wave Propagation in Stratified Acoustic/Porous Media. Part I: the 2D Case. [Research Report] 2008, pp.28. ⟨inria-00274136v1⟩
190 Consultations
892 Téléchargements
