Rewriting Strategies in Java - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
In any language designed to express transformations, the notion of rewrite rule is a key feature. Its conciseness as well as its strong theoretical foundations are essential. The notion of strategy is complementary: this describes how rules are applied. In this paper, we show how a high-level strategy language can be implemented in a Java setting. We present the integration of the visitor combinator design pattern into Tom. This corresponds to an interpreter for strategy expressions. To be more efficient, we present a compilation method based on bytecode specialization. This low-level transformation is expressed in Tom itself, using rules and strategies.
final.pdf (237.58 Ko) Télécharger le fichier
inria-00274919 , version 1 (21-04-2008)
  • HAL Id : inria-00274919 , version 1
Emilie Balland, Pierre-Etienne Moreau, Antoine Reilles. Rewriting Strategies in Java. The Eighth International Workshop on Rule-Based Programming - RBP'07, Jun 2007, Paris, France. ⟨inria-00274919⟩
104 Consultations
193 Téléchargements
