Fine-grained parallelization of similarity search between protein sequences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
This report presents the implementation of a protein sequence comparison algorithm specifically designed for speeding up time consuming part on parallel hardware such as SSE instructions, multicore architectures or graphic boards. Three programs have been developed: PLAST-P, TPLAST-N and PLAST-X. They provide equivalent results compared to the NCBI BLAST family programs (BLAST-P, TBLAST-N and BLAST-X) with a speed-up factor ranging from 5 to 10.
RR-6513.pdf (528.55 Ko) Télécharger le fichier
inria-00275250 , version 1 (23-04-2008)
inria-00275250 , version 2 (23-04-2008)
  • HAL Id : inria-00275250 , version 2
  • ARXIV : 0804.3643
van Hoa Nguyen, Dominique Lavenier. Fine-grained parallelization of similarity search between protein sequences. [Research Report] RR-6513, INRIA. 2008, pp.40. ⟨inria-00275250v2⟩
190 Consultations
149 Téléchargements
