Extraction and simplification of iso-surfaces in tandem, SGP '05: Proceedings of the third Eurographics symposium on Geometry processing, Eurographics Association, p.139, 2005. ,
Surface simplification using quadric error metrics, Annual Conference Series, pp.209-216, 1997. ,
Topological considerations in isosurface generation, ACM Transactions on Graphics, vol.13, issue.4, pp.337-375, 1994. ,
A near optimal isosurface extraction algorithm using the span space, IEEE Transactions on Visualization and Computer Graphics, vol.2, issue.1, pp.73-84, 1996. ,
Marching cubes: A high resolution 3d surface construction algorithm, SIG- GRAPH '87: Proceedings of the 14th annual conference on Computer graphics and interactive techniques, pp.163-169, 1987. ,
Adaptive generation of surfaces in volume data, 1993. ,
A load-balanced parallel implementation of the marching-cubes algorithm, 1995. ,
Complex volumic seismic interpretation by new geobodies extraction strategy, 2007. ,
Octree-based decimation of marching cubes surfaces, IEEE Visualization, pp.335-342, 1996. ,
Octrees for faster isosurface generation, ACM Trans. Graph, vol.11, issue.3, pp.201-227, 1992. ,
