Inductive and Coinductive Components of Corecursive Functions in Coq - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Yves Bertot
In Constructive Type Theory, recursive and corecursive definitions are subject to syntactic restrictions which guarantee termination for recursive functions and productivity for corecursive functions. However, many terminating and productive functions do not pass the syntactic tests. Bove proposed in her thesis an elegant reformulation of the method of accessibility predicates that widens the range of terminative recursive functions formalisable in Constructive Type Theory. In this paper, we pursue the same goal for productive corecursive functions. Notably, our method of formalisation of coinductive definitions of productive functions in Coq requires not only the use of ad-hoc predicates, but also a systematic algorithm that separates the inductive and coinductive parts of functions.
CMCS08BertotKomenda.pdf (261.29 Ko) Télécharger le fichier
dyn.v (4.71 Ko) Télécharger le fichier
exp_filter_s.v (11.36 Ko) Télécharger le fichier
exp_filter_t.v (22.91 Ko) Télécharger le fichier
Format : Autre
Format : Autre
Format : Autre
inria-00277075 , version 1 (05-05-2008)
inria-00277075 , version 2 (09-07-2008)
  • HAL Id : inria-00277075 , version 2
  • ARXIV : 0807.1524
Yves Bertot, Ekaterina Komendantskaya. Inductive and Coinductive Components of Corecursive Functions in Coq. Coalgebraic Methods in Computer Science, Apr 2008, Budapest, Hungary. ⟨inria-00277075v2⟩
Collections
INRIA INRIA2 ANR
463 Consultations
568 Téléchargements
