A necessary condition for dynamic equivalence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2008
If two control systems on manifolds of the same dimension are dynamic equivalent, we prove that either they are static equivalent --i.e. equivalent via a classical diffeomorphism-- or they are both ruled; for systems of different dimensions, the one of higher dimension must ruled. A ruled system is one whose equations define at each point in the state manifold, a ruled submanifold of the tangent space. Dynamic equivalence is also known as equivalence by endogenous dynamic feedback, or by a Lie-Bäcklund transformation when control systems are viewed as underdetermined systems of ordinary differential equations; it is very close to absolute equivalence for Pfaffian systems. It was already known that a differentially flat system must be ruled; this is a particular case of the present result, in which one of the systems is assumed to be "trivial" (or linear controllable).
eqReglFINAL.pdf (267.19 Ko) Télécharger le fichier
inria-00277531 , version 1 (06-05-2008)
inria-00277531 , version 2 (24-11-2008)
  • HAL Id : inria-00277531 , version 1
  • ARXIV : 0805.0721
Jean-Baptiste Pomet. A necessary condition for dynamic equivalence. SIAM Journal on Control and Optimization, 2008. ⟨inria-00277531v1⟩
119 Consultations
239 Téléchargements
