Reports
A Tight Bound for the Delaunay Triangulation of Points on a Polyhedron
Abstract : We show that the Delaunay triangulation of a set of n points distributed nearly uniformly on a p-dimensional polyhedron (not necessarily convex) in d-dimensional Euclidean space is O(n^((d-k+1)/p)), where k = ceil(d+1)/(p+1)$. This bound is tight, and improves on the prior upper bound for most values of p.
Document type :
Reports
Complete list of metadata
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/inria-00277899
Contributor : Olivier Devillers Connect in order to contact the contributor
Submitted on : Tuesday, May 13, 2008 - 10:14:29 AM
Last modification on : Friday, February 4, 2022 - 3:10:50 AM
Long-term archiving on: : Friday, November 25, 2016 - 10:00:38 PM
File
RR-6522.pdf
Identifiers
  • HAL Id : inria-00277899, version 2
Collections
Citation
Nina Amenta, Dominique Attali, Olivier Devillers. A Tight Bound for the Delaunay Triangulation of Points on a Polyhedron. [Research Report] RR-6522, -; INRIA. 2008. ⟨inria-00277899v2⟩
Share
Metrics
Record views
228
Files downloads
209
