Introduction into mathematical aspects of flow control and optimization, in: Lecture series 1997-05 on inverse design and optimization methods, Von Kármán Institute for Fluid Dynamics, 1997. ,
Adjoint Equation-Based Methods for Control Problems in Incompressible, Flow, Turbulence and Combustion, vol.65, issue.3/4, pp.249-272, 2000. ,
DOI : 10.1023/A:1011455900396
A rigorous framework for optimization of expensive functions by surrogates, Structural Optimization, vol.16, issue.1, pp.1-13, 1999. ,
DOI : 10.1007/BF01197708
Approximation of Large-Scale Dynamical Systems, SIAM, 2005. ,
A Reduced-Order Method for Simulation and Control of Fluid Flows, Journal of Computational Physics, vol.143, issue.2, pp.403-425, 1998. ,
DOI : 10.1006/jcph.1998.5943
Atmospheric Turbulence and Wave Propagation. The structure of inhomogeneous turbulence, A, pp.166-178, 1967. ,
Turbulence and the dynamics of coherent structures, Quarterly of Applied Mathematics XLV, issue.3, pp.561-590, 1987. ,
Reduced-order aerodynamic models for aeroelastic control of turbomachines, Massachusetts Institute of Technology, 2000. ,
Centroidal Voronoi Tessellation-Based Reduced-Order Modeling of Complex Systems, SIAM Journal on Scientific Computing, vol.28, issue.2, 2004. ,
DOI : 10.1137/5106482750342221x
MODEL REDUCTION FOR FLUIDS, USING BALANCED PROPER ORTHOGONAL DECOMPOSITION, International Journal of Bifurcation and Chaos, vol.15, issue.03, pp.997-1013, 2005. ,
DOI : 10.1142/S0218127405012429
A low-dimensional model for simulating threedimensional cylinder flow, J. Fluid Mech, vol.458, pp.181-190, 2002. ,
A hierarchy of low-dimensional models for the transient and post-transient cylinder wake, Journal of Fluid Mechanics, vol.497, pp.335-363, 2003. ,
DOI : 10.1017/S0022112003006694
Low-Dimensional Models for Feedback Flow Control. Part I: Empirical Galerkin Models, 2nd AIAA Flow Control Conference, 2004. ,
DOI : 10.2514/6.2004-2408
Optimal rotary control of the cylinder wake using POD Reduced Order Model, Phys. Fluids, vol.17, issue.097101, pp.1-21, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00338850
Optimal control of vortex shedding using low-order models. Part I?open-loop model development, International Journal for Numerical Methods in Engineering, vol.111, issue.224, pp.945-972, 1999. ,
DOI : 10.1002/(SICI)1097-0207(19990310)44:7<945::AID-NME537>3.0.CO;2-F
Reduced-order adaptive controllers for fluid flows using POD, Journal of Scientific Computing, vol.15, issue.4, pp.457-478, 2000. ,
DOI : 10.1023/A:1011184714898
Adaptive Reduced-Order Controllers for a Thermal Flow System, SIAM Journal on Scientific Computing, vol.23, issue.6, pp.1925-1943, 2002. ,
Proper Orthogonal Decomposition Surrogate Models for Nonlinear Dynamical Systems: Error Estimates and Suboptimal Control, 2004. ,
DOI : 10.1007/3-540-27909-1_10
Vortex Dynamics in the Cylinder Wake, Annual Review of Fluid Mechanics, vol.28, issue.1, pp.477-539, 1996. ,
DOI : 10.1146/annurev.fl.28.010196.002401
Rotary oscillation control of a cylinder wake, Journal of Fluid Mechanics, vol.182, issue.-1, pp.77-90, 1991. ,
DOI : 10.1017/S0022112088001570
A NUMERICAL STUDY OF FLOW PAST A ROTATIONALLY OSCILLATING CIRCULAR CYLINDER, Journal of Fluids and Structures, vol.10, issue.8, pp.829-849, 1996. ,
DOI : 10.1006/jfls.1996.0055
Synchronization of vortex shedding from a cylinder under rotary oscillation, Computers & Fluids, vol.26, issue.8, pp.755-774, 1997. ,
DOI : 10.1016/S0045-7930(97)00028-5
Numerical simulation of the flow behind a rotary oscillating circular cylinder, Physics of Fluids, vol.10, issue.4, pp.869-876, 1998. ,
DOI : 10.1063/1.869610
Flow Structure in the Wake of a Rotationally Oscillating Cylinder, Journal of Fluids Engineering, vol.122, issue.2, pp.290-301, 2000. ,
DOI : 10.1115/1.483257
Quasi-periodicity in the wake of a rotationally oscillating cylinder, Journal of Fluid Mechanics, vol.408, pp.275-300, 2000. ,
DOI : 10.1017/S0022112099007855
NUMERICAL INVESTIGATION OF A ROTATIONALLY OSCILLATING CYLINDER IN MEAN FLOW, Journal of Fluids and Structures, vol.15, issue.7, pp.981-1007, 2001. ,
DOI : 10.1006/jfls.2001.0387
Numerical simulation of flow past a rotationally oscillating cylinder, Computers & Fluids, vol.30, issue.3, pp.365-392, 2001. ,
DOI : 10.1016/S0045-7930(00)00012-8
Characteristics of flow over a rotationally oscillating cylinder at low Reynolds number, Physics of Fluids, vol.14, issue.8, pp.2767-2777, 2002. ,
DOI : 10.1063/1.1491251
Drag force in the open-loop control of the cylinder wake in the laminar regime, Physics of Fluids, vol.14, issue.2, pp.810-826, 2002. ,
DOI : 10.1063/1.1432695
VORTEX SHEDDING RESONANCE FROM A ROTATIONALLY OSCILLATING CYLINDER, Journal of Fluids and Structures, vol.12, issue.8, pp.1041-1053, 1998. ,
DOI : 10.1006/jfls.1998.0178
FEEDBACK CONTROL OF VORTEX SHEDDING FROM A CIRCULAR CYLINDER BY ROTATIONAL OSCILLATIONS, Journal of Fluids and Structures, vol.15, issue.1, pp.23-37, 2001. ,
DOI : 10.1006/jfls.2000.0323
Contrôle actif du sillage autour d'un cylindre oscillant, 15th French Congress of Mechanics, 2001. ,
The wake of a cylinder performing rotary oscillations, Journal of Fluid Mechanics, vol.560 ,
DOI : 10.1017/S0022112006000656
On some control problems in fluid mechanics, Theoretical and Computational Fluid Dynamics, vol.10, issue.4, 1990. ,
DOI : 10.1007/BF00271794
Flow control: new challenges for a new Renaissance, Progress in Aerospace Sciences, vol.37, issue.1, pp.21-58, 2001. ,
DOI : 10.1016/S0376-0421(00)00016-6
The emerging roles of model-based control theory in fluid mechanics , in: Advances in Turbulence IX, 2002. ,
Active control and drag optimization for flow past a circular cylinder. Part 1. Oscillatory cylinder rotation, J. Comp. Phys, pp.163-83, 2000. ,
Suppression of vortex shedding for flow around a circular cylinder using optimal control, International Journal for Numerical Methods in Fluids, vol.11, issue.1, pp.43-69, 2002. ,
DOI : 10.1002/fld.203
Optimal rotary control of the cylinder wake in the laminar regime, Physics of Fluids, vol.14, issue.7, pp.2073-2087, 2002. ,
DOI : 10.1063/1.1476671
DNS-based predictive control of turbulence: an optimal benchmark for feedback algorithms, Journal of Fluid Mechanics, vol.447, pp.179-225, 2001. ,
DOI : 10.1017/S0022112001005821
Approximate models for optimal control of turbulent channel flow, Rice university, 2000. ,
A noise-controlled free shear flow, Journal of Fluid Mechanics, vol.546, issue.-1, pp.123-152, 2006. ,
DOI : 10.1017/S0022112005007093
A trust-region framework for managing the use of approximation models in optimization, Structural Optimization, vol.12, issue.1, pp.97-50 ,
DOI : 10.1007/BF01197433
On the power used to control the circular cylinder drag by rotary oscillations, Phys. Fluids, vol.18, issue.088103, pp.1-4, 2006. ,
A global stability analysis of the steady and periodic cylinder wake, Journal of Fluid Mechanics, vol.74, issue.-1, pp.297-330, 1994. ,
DOI : 10.1016/0167-2789(92)90021-E
Three-dimensional Floquet stability analysis of the wake of a circular cylinder, Journal of Fluid Mechanics, vol.199, issue.-1, pp.215-241, 1996. ,
DOI : 10.1016/0021-9991(91)90007-8
Proper Orthogonal Decomposition: an overview, in: Lecture series 2002-04 on post-processing of experimental and numerical data, Von Kármán Institute for Fluid Dynamics, 2002. ,
Optimal control of vortex shedding using low-order models. Part II?model-based control, International Journal for Numerical Methods in Engineering, vol.44, issue.7, pp.973-990, 1999. ,
DOI : 10.1002/(SICI)1097-0207(19990310)44:7<973::AID-NME538>3.0.CO;2-F
Numerical Optimization, Springer series in operations research, 1999. ,
A Nonreflecting Outlet Boundary Condition for Incompressible Unsteady Navier-Stokes Calculations, Journal of Computational Physics, vol.107, issue.2, pp.239-253, 1993. ,
DOI : 10.1006/jcph.1993.1140
Two typical applications of POD: coherent structures eduction and reduced order modelling, in: Lecture series 2002-04 on post-processing of experimental and numerical data, Von Kármán Institute for Fluid Dynamics, 2002. ,
Optimisation aérodynamique par réduction de modèle POD et contrôle optimal Application au sillage laminaire d'un cylindre circulaire, 2004. ,
On the relation between the global modes and the spectra of drag and lift in periodic wake flows, Comptes Rendus M??canique, vol.331, issue.1, pp.49-54, 2003. ,
DOI : 10.1016/S1631-0721(02)00018-9
Numerical study and physical analysis of the pressure and velocity fields in the near wake of a circular cylinder, Journal of Fluid Mechanics, vol.49, issue.-1, p.79, 1986. ,
DOI : 10.1063/1.1692470
Nonlinear dynamics and pattern formation in turbulent wake transition, Journal of Fluid Mechanics, vol.352, pp.65-112, 1997. ,
DOI : 10.1017/S0022112097007465
On the generation of a reverse von K??rm??n street for the controlled cylinder wake in the laminar regime, Physics of Fluids, vol.18, issue.2, pp.28101-28102, 2006. ,
DOI : 10.1063/1.2171193
Robust and optimal control, 1996. ,
The need for a pressure-term representation in empirical Galerkin models of incompressible shear flows, Journal of Fluid Mechanics, vol.523, pp.339-365, 2005. ,
DOI : 10.1017/S0022112004002149
Low-order modelling of laminar flow regimes past a confined square cylinder, Journal of Fluid Mechanics, vol.503, pp.161-170, 2004. ,
DOI : 10.1017/S0022112004007906
Calibrated reduced-order POD-Galerkin system for fluid flow modelling, Journal of Computational Physics, vol.207, issue.1, pp.192-220, 2005. ,
DOI : 10.1016/j.jcp.2005.01.008
A spectral viscosity method for correcting the long-term behavior of POD models, Journal of Computational Physics, vol.194, issue.1, pp.92-116, 2004. ,
DOI : 10.1016/j.jcp.2003.08.021
Large Eddy Simulation for Incompressible Flows. An Introduction, Measurement Science and Technology, vol.12, issue.10, 2005. ,
DOI : 10.1088/0957-0233/12/10/707
A Spectral Vanishing Viscosity Method for Large-Eddy Simulations, Journal of Computational Physics, vol.163, issue.1, pp.22-50, 2000. ,
DOI : 10.1006/jcph.2000.6552
Trust-Region Proper Orthogonal Decomposition for Flow Control ,
Trust-region methods, 2000. ,
DOI : 10.1137/1.9780898719857
Global Convergence of a a of Trust-Region Methods for Nonconvex Minimization in Hilbert Space, IMA Journal of Numerical Analysis, vol.8, issue.2, pp.231-252, 1988. ,
DOI : 10.1093/imanum/8.2.231
Investigations of boundary layer transition via Galerkin projections on empirical eigenfunctions, Physics of Fluids, vol.8, issue.1, pp.175-188, 1996. ,
DOI : 10.1063/1.868825
Low???dimensional models for complex geometry flows: Application to grooved channels and circular cylinders, Physics of Fluids A: Fluid Dynamics, vol.3, issue.10, pp.2337-2354, 1991. ,
DOI : 10.1063/1.857881
Evolution of three-dimensional coherent structures in a flat-plate boundary layer, Journal of Fluid Mechanics, vol.104, issue.-1, pp.351-375, 1994. ,
DOI : 10.1063/1.857573
Adaptive control of a wake flow using Proper Orthogonal Decomposition, in: Shape Optimization and Optimal Design, Lecture Notes in Pure and Applied Mathematics, vol.216, 2001. ,
Error Estimation for Reduced Order Models of Dynamical Systems, 2003. ,
Europe -38334 Montbonnot Saint-Ismier Centre de recherche INRIA Lille ? Nord Europe : Parc Scientifique de la Haute Borne -40, avenue Halley -59650 Villeneuve d'Ascq Centre de recherche INRIA Nancy ? Grand Est : LORIA, Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès-Nancy Cedex Centre de recherche INRIA Paris ? Rocquencourt : Domaine de Voluceau -Rocquencourt -BP 105 -78153 Le Chesnay Cedex Centre de recherche INRIA Rennes ? Bretagne Atlantique : IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex Centre de recherche INRIA Saclay ? Île-de-France, des Vignes : 4, rue Jacques Monod -91893 BP 105 -78153 Le Chesnay Cedex (France) ØØÔÔ»»ÛÛÛººÒÖÖÖººÖ, 2004. ,
