Wireless Broadcast with Network Coding: A Connected Dominating Sets Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
We study network coding for multi-hop wireless networks. We focus the case of broadcasting, where one source transmits information to all the nodes in the network. Our goal is energy-efficient broadcasting, in other words, to minimize the number of transmissions for broadcasting to the entire network. To achieve this goal, we propose a family of methods that combine the use of network coding and connected dominating sets. They consists in rate selections using connected dominated sets (RAUDS: Rate Adjustment Using Dominating Sets, and an generalized version, MARAUDS). The main insight behind these methods is that their use of connected dominating sets, allows near-optimality in the core of the network, while they efficiently handle borders and non-uniformity. The main contribution is a formal proof of the performance of these families of algorithms. One main result is the comparison of performance between routing and these methods (and in general, network coding).
RR-6547.pdf (770.61 Ko) Télécharger le fichier
inria-00284317 , version 1 (02-06-2008)
inria-00284317 , version 2 (04-06-2008)
  • HAL Id : inria-00284317 , version 2
Cédric Adjih, Song Yean Cho. Wireless Broadcast with Network Coding: A Connected Dominating Sets Approach. [Research Report] RR-6547, INRIA. 2008. ⟨inria-00284317v2⟩
164 Consultations
97 Téléchargements
