Teaching programming methodology using Event B - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Event B is supported by the RODIN platform and provides a framework for teaching programming methodology based on the famous pre/post specifications, together with the refinement. We illustrate a methodology based on Event B and the refinement by developing Floyd's algorithm for computing the shortest distances of a graph, which is based on an algorithm design technique called dynamic programming. The development is based on a paradigm identifying a non-deterministic event with a procedure call and by introducing control states. We discuss points related to our lectures at the university.
entcsmery.pdf (293.45 Ko) Télécharger le fichier
inria-00287231 , version 1 (11-06-2008)
inria-00287231 , version 2 (13-11-2008)
  • HAL Id : inria-00287231 , version 2
Dominique Méry. Teaching programming methodology using Event B. The B Method: from Research to Teaching, Henri Habrias, Jul 2008, Nantes, France. ⟨inria-00287231v2⟩
92 Consultations
163 Téléchargements
