A Simple Modification in CMA-ES Achieving Linear Time and Space Complexity - Archive ouverte HAL Access content directly
Conference Papers Year : 2008
(1) , (1, 2)
1
2
This paper proposes a simple modification of the Covariance Matrix Adaptation Evolution Strategy (CMA-ES) for high dimensional objective functions, reducing the internal time and space complexity from quadratic to linear. The covariance matrix is constrained to be diagonal and the resulting algorithm, sep-CMA-ES, samples each coordinate independently. Because the model complexity is reduced, the learning rate for the covariance matrix can be increased. Consequently, on essentially separable functions, sep-CMA-ES significantly outperforms CMA-ES. For dimensions larger than a hundred, even on the non-separable Rosenbrock function, the sep-CMA-ES needs fewer function evaluations than CMA-ES.
sepCMA_PPSN2008HAL.pdf (194.37 Ko) Télécharger le fichier
Dates and versions
inria-00287367 , version 1 (23-06-2008)
Identifiers
  • HAL Id : inria-00287367 , version 1
Cite
Raymond Ros, Nikolaus Hansen. A Simple Modification in CMA-ES Achieving Linear Time and Space Complexity. 10th International Conference on Parallel Problem Solving From Nature, Sep 2008, Dortmund, Germany. ⟨inria-00287367⟩
473 View
1473 Download
Share
