Structure Extraction in Printed Documents Using Neural Approaches
This paper addresses the problem of layout and logical structure extraction from image documents. Two classes of approaches are first studied and discussed in general terms: data-driven and model-driven. In the latter, some specific approaches like rule-based or formal grammar are usually studied on very stereotyped documents providing honest results, while in the former artificial neural networks are often considered for small patterns with good results. Our understanding of these techniques let us to believe that a hybrid model is a more appropriate solution for structure extraction. Based on this standpoint, we proposed a Perceptive Neural Network based approach using a static topology that possesses the characteristics of a dynamic neural network. Thanks to its transparency, it allows a better representation of the model elements and the relationships between the logical and the physical components. Furthermore, it possesses perceptive cycles providing some capacities in data refinement and correction. Tested on several kinds of documents, the results are better than those of a static Multilayer Perceptron.
