New interface
Reports (Technical report)
Resource management with Qinna framework : the remote viewer case study
Abstract : Even if hardware improvements have increase the performance of embedded systems in the last years, resource problems are still accurate. In fact, the persisting problem is the constantly growing complexity of systems. In addition, new supports of service such as PDAs or smartphones increase the need for flexible and adaptable open software. Component-based software engineering tries to address these problems and one key point for development is the Quality of Service (QoS) coming from resource constraints. In this technical report, we recall the concepts behind Qinna, a component-based QoS Architecture, which was designed to manage QoS issues, and we illustrate the developpement of a image viewer application whithin this framework. We focus on the general developpement methodology of resource-aware applications with Qinna framework, from the specification of resource constraints to the use of generic Qinna's algorithms for negociating QoS contracts at runtime.
Document type :
Complete list of metadata
Cited literature [6 references]  Display  Hide  Download
https://hal.inria.fr/inria-00288593
Contributor : Laure Gonnord Connect in order to contact the contributor
Submitted on : Tuesday, June 24, 2008 - 10:49:48 AM
Last modification on : Wednesday, October 26, 2022 - 8:14:03 AM
Long-term archiving on: : Friday, November 25, 2016 - 10:03:43 PM
File
RR-6562.pdf
Identifiers
  • HAL Id : inria-00288593, version 2
Collections
Citation
Laure Gonnord, Jean-Philippe Babau. Resource management with Qinna framework : the remote viewer case study. [Technical Report] RR-6562, INRIA. 2008. ⟨inria-00288593v2⟩
Share
Metrics
Record views
411
Files downloads
86
