A Simple Mechanism to Reproduce the Neural Solution of the Aperture Problem in Monkey Area MT [ RR-6579] - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
We propose a simple mechanism to reproduce the neural solution of the aperture problem in monkey area MT. More precisely, our goal is to propose a model able to reproduce the dynamical change of the preferred direction (PD) of a MT cell depending on the motion information contained in the input stimulus. The PD of a MT cell measured through drifting gratings differs of the one measured using a barberpole, which is highly related with its aspect ratio. For a barberpole, the PD evolves from the perpendicular direction of the drifting grating to a PD shifted according to the aspect ratio of the barberpole. The mechanisms underlying this dynamic are unknown (lateral connections, surround suppression, feed-backs from higher layers). Here, we show that a simple mechanism such as surround-inhibition in V1 neurons can produce a significant shift in the PD of MT neurons as observed with barberpoles of different aspect ratios
RR_6579.pdf (682.07 Ko) Télécharger le fichier
inria-00290759 , version 1 (26-06-2008)
inria-00290759 , version 2 (11-07-2008)
  • HAL Id : inria-00290759 , version 2
Maria-Jose Escobar, Guillaume S. Masson, Pierre Kornprobst. A Simple Mechanism to Reproduce the Neural Solution of the Aperture Problem in Monkey Area MT [ RR-6579]. [Research Report] RR-6579, INRIA. 2008. ⟨inria-00290759v2⟩
276 Consultations
205 Téléchargements
