Consistency restoration and explanations in dynamic CSPs???Application to configuration, Artificial Intelligence, vol.135, issue.1-2, pp.199-234, 2002. ,
DOI : 10.1016/S0004-3702(01)00162-X
An overview of the kl-one knowledge representation system, Cognitive Science, vol.9, issue.2, pp.171-216, 1985. ,
Ant colony optimization theory: A survey, Theoretical Computer Science, vol.344, issue.2-3, pp.243-278, 2005. ,
DOI : 10.1016/j.tcs.2005.05.020
Ant Algorithms for Discrete Optimization, Artificial Life, vol.54, issue.1, pp.137-172, 1999. ,
DOI : 10.1007/BF01797237
Ant colony system: a cooperative learning approach to the traveling salesman problem, IEEE Transactions on Evolutionary Computation, vol.1, issue.1, pp.53-66, 1997. ,
DOI : 10.1109/4235.585892
A new optimizer using particle swarm theory, MHS'95. Proceedings of the Sixth International Symposium on Micro Machine and Human Science, pp.39-43, 1995. ,
DOI : 10.1109/MHS.1995.494215
Configuring largescale systems with generative constraint satisfaction, IEEE Intelligent Systems -Special issue on Configuration, 1998. ,
Advances in Polytime Isomorph Elimination for Configuration, proceedings of Principles and Practice of Constraint Programming -CP 2005, pp.301-313, 2005. ,
DOI : 10.1007/11564751_24
The logic of ilog (j)configurator : Combining constraint programming with a description logic, proceedings of Workshop on Configuration, IJCAI'03, 2003. ,
Symmetry breaking in a rack configuration problem, Proc. of the IJCAI'01 Workshop on Modelling and Solving Problems with Constraints, 2001. ,
Conceptual modelling for configuration : A description logicbased approach, AI EDAM, vol.12, issue.4, pp.333-344, 1998. ,
Dynamic constraint satisfaction problems, AAAI, pp.25-32, 1990. ,
Configuration as composite constraint satisfaction. Artificial Intelligence and Manufacturing Research Planning Workshop, pp.153-161, 1996. ,
Representing configuration knowledge with weight constraint rules, Answer Set Programming, 2001. ,
Ants can solve constraint satisfaction problems, IEEE Transactions on Evolutionary Computation, vol.6, issue.4, pp.347-357, 2002. ,
DOI : 10.1109/TEVC.2002.802449
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.16.8960
An overview of knowledge-based configuration, pp.111-125, 1997. ,
A generative constraint formalism for configuration problems, Lecture Notes in Computer Science, vol.728, pp.302-313, 1993. ,
DOI : 10.1007/3-540-57292-9_68
??? Ant System, Future Generation Computer Systems, vol.16, issue.8, pp.889-914, 2000. ,
DOI : 10.1016/S0167-739X(00)00043-1
