Automatic Middleware Deployment Planning on Heterogeneous Platforms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
The use of many distributed, heterogeneous resources as a large collective platform offers great potential. A key issue for these grid platforms is middleware scalability and how middleware services can be mapped on the available resources. Optimizing deployment is a difficult problem with no existing general solutions. In this paper, we address the following problem: how to perform out an adapted deployment for a hierarchy of servers and resource brokers on a heterogeneous system? Our objective is to generate a best platform from the available nodes so as to fulfill the clients demands. However, finding the best deployment among heterogeneous resources is a hard problem since it is close to find the best broadcast tree in a general graph, which is known to be NP-complete. Thus, in this paper, we present a heuristic for middleware deployment on heterogeneous resources. We apply our heuristic to automatically deploy a distributed Problem Solving Environment on a large scale grid. We present experiments comparing the automatically generated deployment against a number of other reasonable deployments.
rr_hcw08.inria.pdf (192.95 Ko) Télécharger le fichier
inria-00291515 , version 1 (27-06-2008)
inria-00291515 , version 2 (01-07-2008)
  • HAL Id : inria-00291515 , version 2
Eddy Caron, Pushpinder Kaur Chouhan, Frédéric Desprez. Automatic Middleware Deployment Planning on Heterogeneous Platforms. [Research Report] RR-6566, INRIA. 2008, pp.20. ⟨inria-00291515v2⟩
275 Consultations
232 Téléchargements
