Recognizing disguised NR(1) instances of the satisfiability problem, Journal of Algorithms, vol.1, issue.1, pp.97-103, 1980. ,
DOI : 10.1016/0196-6774(80)90007-3
Transformations between signed and classical clause logic [3] Christian Bessiere. Constraint propagation, Proc. 29th IEEE International Symposium on Multiple-Valued Logic (ISMVL'99) Handbook of Constraint Programming, pp.248-255, 1999. ,
DOI : 10.1109/ismvl.1999.779724
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.28.5605
Structure identification in relational data, Artificial Intelligence, vol.58, issue.1-3, pp.237-270, 1992. ,
DOI : 10.1016/0004-3702(92)90009-M
Constraint satisfaction over connected row-convex constraints, Artificial Intelligence, vol.109, issue.1-2, pp.243-271, 1999. ,
DOI : 10.1016/S0004-3702(99)00012-0
URL : http://doi.org/10.1016/s0004-3702(99)00012-0
Domain permutation reduction for constraint satisfaction problems, Artificial Intelligence, vol.172, pp.1094-1118, 2008. ,
A linear algorithm for renaming a set of clauses as a Horn set, Theoretical Computer Science, vol.124, issue.2, pp.343-350, 1994. ,
DOI : 10.1016/0304-3975(94)90015-9
Constraints, consistency and closure, Artificial Intelligence, vol.101, issue.1-2, pp.251-265, 1998. ,
DOI : 10.1016/S0004-3702(98)00022-8
Tractable constraints on ordered domains, Artificial Intelligence, vol.79, pp.327-339, 1995. ,
Networks of constraints: Fundamental properties and applications to picture processing, Information Sciences, vol.7, pp.95-132, 1974. ,
DOI : 10.1016/0020-0255(74)90008-5
The complexity of satisfiability problems, Proceedings of the tenth annual ACM symposium on Theory of computing , STOC '78, pp.216-226, 1978. ,
DOI : 10.1145/800133.804350
When do bounds and domain propagation lead to the same search space, Proc. 3rd International Conference on Principles and Practice of Declarative Programming (PPDP'01), pp.115-126, 2001. ,
On the minimality and global consistency of row-convex constraint networks, Journal of the ACM, vol.42, issue.3, pp.543-561, 1995. ,
DOI : 10.1145/210346.210347
A generic arc-consistency algorithm and its specializations, Artificial Intelligence, vol.57, issue.2-3, pp.291-321, 1992. ,
DOI : 10.1016/0004-3702(92)90020-X
An efficient algorithm for a class of constraint satisfaction problems, Operations Research Letters, vol.30, issue.1, pp.9-16, 2002. ,
DOI : 10.1016/S0167-6377(01)00114-6
A unified framework for structure identification, Information Processing Letters, vol.81, issue.6, pp.335-339, 2002. ,
DOI : 10.1016/S0020-0190(01)00247-2
URL : https://hal.archives-ouvertes.fr/hal-00995240
