Semiring-based CSPs and Valued CSPs : Frameworks, Properties, and Comparaison, Constraints, vol.4, issue.3, pp.199-240, 1970. ,
DOI : 10.1023/A:1026441215081
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.52.5664
Vertex-weighted matching algorithms for computing column-space bases, CSC05, 2005. ,
Constructing Maximal Dynamic Flows from Static Flows, Operations Research, vol.6, issue.3, pp.419-433, 1958. ,
DOI : 10.1287/opre.6.3.419
Partial Constraint Satisfaction, IJCAI, vol.89, issue.58, pp.1-3, 1989. ,
DOI : 10.1007/3-540-61479-6_18
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.14.7954
A n 5/2 algorithm for maximum matchings in bipartite graphs, FOCS, pp.122-125, 1971. ,
Preferred Explanations and Relaxations for Over- Constrained Problems, 2004. ,
Solving weighted CSP by maintaining arc consistency, Artificial Intelligence, vol.159, issue.1-2, pp.1-26, 2004. ,
DOI : 10.1016/j.artint.2004.05.004
URL : http://doi.org/10.1016/j.artint.2004.05.004
?-alldifferent : Softening alldifferent in weighted csps, pp.223-230, 2007. ,
A Regular Language Membership Constraint for Finite Sequences of Variables, Lecture Notes in Computer Science, vol.3258, pp.482-495, 2004. ,
DOI : 10.1007/978-3-540-30201-8_36
A General Conflict- Set Based Framework for Partial Constraint Satisfaction, 2003. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00269780
Specific Filtering Algorithms for Over-Constrained Problems, Lecture Notes in Computer Science, vol.2239, pp.451-463, 2001. ,
DOI : 10.1007/3-540-45578-7_31
Singleton Consistencies, Lecture Notes in Computer Science, vol.1894, pp.353-368, 2000. ,
DOI : 10.1007/3-540-45349-0_26
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.30.4233
Improved Algorithms for the Global Cardinality Constraint, LNCS, vol.3258, pp.542-556, 2004. ,
DOI : 10.1007/978-3-540-30201-8_40
A Filtering Algorithm for Constraints of Difference in CSPs, pp.362-367, 1994. ,
Generalized Arc Consistency for Global Cardinality Constraint, AAAI-96, pp.209-215, 1996. ,
Depth-First Search and Linear Graph Algorithms, SIAM Journal on Computing, pp.146-160, 1972. ,
DOI : 10.1109/swat.1971.10
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.327.8418
A generic arc-consistency algorithm and its specializations, Artificial Intelligence, vol.57, issue.2-3, pp.2-391, 1992. ,
DOI : 10.1016/0004-3702(92)90020-X
A Hyper-arc Consistency Algorithm for the Soft Alldifferent Constraint, LNCS, vol.3258, pp.679-689, 2004. ,
DOI : 10.1007/978-3-540-30201-8_49
On global warming: Flow-based soft global constraints, Journal of Heuristics, vol.1, issue.4, pp.347-373, 2006. ,
DOI : 10.1007/s10732-006-6550-4
Improved Algorithm for the Soft Global Cardinality Constraint, CPAIOR 2006, pp.288-299, 2006. ,
DOI : 10.1007/11757375_23
